Drag Racing Tech
how to remove the front sway bar??
Old Oct 9, 2005 | 01:07 PM
Mr_president's Avatar
Default how to remove the front sway bar??
ok well im not sure where it is but im going to look haha ....do you really need it and how much weight does it shave ..will it hurt me??
Old Oct 9, 2005 | 01:37 PM
CrawlinWS6's Avatar
Import Patrol
I took mine off, Its right behind the front air damn. When I took mine off, and all hardware that is included, I lost 16lbs. The only thing I noticed when I took mine off, is that the steering wheel is just a little looser.
Old Oct 11, 2005 | 05:29 PM
blind527's Avatar
Will it hurt on the street? Do you need any aftermarket or extra pieces to remove it? Is it fine for daily driving or long trips?
Old Oct 13, 2005 | 04:33 AM
94FBIRD's Avatar
Sorry, but you cannot remove it easily. It is welded to the front subframe of the car.
Old Oct 13, 2005 | 04:37 AM
94FBIRD's Avatar
Actually, it IMHO it makes cornering silly. Don't even try it. Every corner should be 20 MPH under the recomended speed limit.
Old Oct 13, 2005 | 10:26 AM
CrawlinWS6's Avatar
Import Patrol
Ah..... NO! maybe its different on your lt1. But on the ls1's you remove the sway bar links (easier to cut, they get rusty as hell). Then there are (2) bushing brackets, that you remove the 2 bolts out and then the sway bar will drop.
As far as not being safe. I don't know about running normal wheels and tires, since I run front skinnies, but as far as cornering, i still corner without a problem. I did not notice anything while cornering, just while on the highway the steering is alittle looser. But I don't regret it at all.
Old Oct 13, 2005 | 11:28 AM
blind527's Avatar
.........no. I've seen how to easily remove it. How else do other people bolt on front sway bars on an LT1.........
Old Oct 13, 2005 | 12:42 PM
Turo's Avatar
Its a tradeoff: cornering ability definitely goes down, but you can feel the car has better weight transfer on a launch. My daily driver has no front swaybar and I have no intentions on putting it back, but if I didn't drag race the car I would have definitely left it on.
Old Oct 13, 2005 | 04:33 PM
mongse's Avatar
I ruin the end of films...
Same on my LTx car. Mine fell off a long time ago. 6 bolts total if I remember correctly.
