Drag Racing Tech
Quick transbrake question...
Old Oct 13, 2005 | 01:54 PM
xssive's Avatar
Default Quick transbrake question...
So to get into reverse, I have to put the shifter into the reverse position and hit the transbrake button? I have heard you can put it into neutral as well and do the same thing?
Old Oct 13, 2005 | 01:57 PM
MADMAN's Avatar
LS1Tech Sponsor
Depends on the valve body.
__________________
www.madmanandcoracing.com
225-343-9029
Old Oct 13, 2005 | 02:13 PM
The Juggernaut's Avatar
Pressing the button is reverse.
Old Oct 13, 2005 | 02:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Depends on the valve body, I just have to hit my reverse lockout.
Old Oct 13, 2005 | 02:34 PM
DERTY's Avatar
The Bull
Depends on the valvebody as it was stated. Some, like my Rossler TH400 have a reverse gate and it actually goes into gear without the button. Others, like Harlans glide from Hutch you have a reverse gate, but you have to hold the transbrake to get reverse to engage.
Old Oct 13, 2005 | 02:49 PM
Sandmann120's Avatar
I know on mine, I have to have it in neutral, and press the button.
Old Oct 13, 2005 | 03:09 PM
Tom the roofer's Avatar
I have a Rossler T-brake in my glide. I had my choice of a sportsman (goes into reverse gear when put into the reverse location) or a pro T-brake (put it in the reverse gear location and pressing the t-brake button is required. I have the pro.
Old Oct 13, 2005 | 03:22 PM
1fastWS6's Avatar
Wire it up with a secondary toggle switch....tons easier than holding the button. Try backing up, while turning, and still holding the 'brake button on the steering wheel. MAJOR PITA.
FYI, mine doesn't go into reverse unless the trans is in "R". It's a Tranzking vb.
Old Oct 13, 2005 | 04:19 PM
xssive's Avatar
I just talked to the guys at PTC and they said I have to have it in neutral and hit the t-brake. Whats the point of even having a reverse position in the linkage then? So that brings me to the next question...
What kind of amperage do these t-brake solenoids pull? Should I wire it through a relay, on its own cirtuit...?
Old Oct 13, 2005 | 04:39 PM
68maro's Avatar
7 Second Club / STF Veteran
i know the coan big dog th400 i have if you put it in reverse it will burn the trans up you have to put it in neutral and hold the button.
