Drag Racing Tech
What is a two step?
Old Oct 10, 2005 | 09:58 PM
02ls1cs's Avatar
Default What is a two step?
did a search, couldnt find my answer. tia
Old Oct 11, 2005 | 04:12 AM
DMH Fabrication's Avatar
two step is a rev limiter. One limit is set lower for your launch rpm and the other is your normal rev limiter. Basically a 2 step lets you launch your car at whatever rpm you want, you just hold down the gas. Also if you have a turbo, a 2 step wil let you build boost off the line in a manual car. Hope that helps some
Old Oct 11, 2005 | 10:15 AM
02ls1cs's Avatar
yea that was what i was looking for. thanks a lot i appreciate the fast response
Old Oct 11, 2005 | 04:26 PM
mongse's Avatar
I ruin the end of films...
It's a dance that originated in the 1800s, but that's not important right now.
69vette is right. It's real helpful on a turbo car b/c it causes a misfire that will build boost faster.
Old Oct 13, 2005 | 10:08 PM
ATLHwyRacer's Avatar
Its a song by Ciara (1, 2 step)
