Madman reason to KEEP the front swaybar?
Here is what I do, install the Front sway but when you get to the track just unhook both ends. it only takes about 15 minutes to do. If you want buy a $60 STB install that while your driving around town and take it off at the track (once again 10 min install/uninstall). I never belived a peice of steel across the engine bay could firm the car up as much as it did.
If you put in an airbag and still have a passenger side spin on the launch you need to add more air. How much psi do you have in it right now? I'll take a guess here and say you'll need about 32psi to level the launch.
A test that might help is to foot brake the car and have some measure each side of the rear of the body from the ground. Go back and add air until they are even under load of footbraking.
http://incontt.com/videos/launch1.wmv
and thanks guys for the help!!!!
lca are in middle hole with just a slight uphill rise to the front..(tried to get Madmans 2 deg setting.) They used to be on the bottom.
BMR tq arm is set -2deg pinion angle as compared to the frame of the car...not the driveshaft.
I just switched to a th400 and the bmr crossmember with torque arm mount has adjustments for the torq arm mount to move instant center. You can add that in to things i can try and i will listen to all ideas.
What's with the 2 tone paint job?
so its safe to daily drive with that? (Including Hwy speeds)
Also, isnt that an ANTI-Roll bar?
Mounted:
http://psj.ls1tech.com/gallery/main....&g2_itemId=676
