Drag Racing Tech
Questions after dash removal
Old Oct 21, 2005 | 08:26 AM
1_Bad_LS1's Avatar
Default Questions after dash removal
I pulled the dash out to remove the blower motor, airbag etc... After putting it all back together, I have no control of my power accesories on my doors (Windows, locks, mirrors)... I am assuming I just forgot a connector somewhere, but after looking all around there I could not find anything... Any of you guys had this issue and have a direction thata I could start looking?
Thanks in advance
Old Oct 21, 2005 | 10:13 AM
12secSS's Avatar
Sounds like you missed a connection associated with the BCM, possibly a connector or fuse.
Old Oct 21, 2005 | 10:43 AM
Reckless's Avatar
Super Moderator
Yeah, did you remove the body control mudule? It is about 6" x 4" and mounted under there near the blower box and operates those things.
Old Oct 21, 2005 | 10:45 AM
Tom the roofer's Avatar
Same thing happened to me. Mine was the ground wire that attaches to the drivers side nut and fixed bolt (to the extreme left about shin level or so ) was not reconnected after dash removal. Check the ground wires.
Old Oct 21, 2005 | 11:33 AM
1_Bad_LS1's Avatar
Tom you are a genious... either that or I am a dumbass!!! I think I forgot that ground on the drivers side... I will check when I get home...
Thanks alot guys... Thats why I love this place...
BTW, My BCM is intact, I read someone elses horror story about that before I started removing stuff...
Old Oct 22, 2005 | 10:32 AM
Loudmouth LS1's Avatar
So if you don't have power windows/locks/mirrors, can you take the bcm out?
Old Oct 25, 2005 | 09:47 PM
SLOZ's Avatar
Yes, you can.
Old Oct 25, 2005 | 09:51 PM
J_TGuerra's Avatar
yea thats the most common missed item when replacing a dash.. damn grounds always find a place to hide lol
Old Oct 26, 2005 | 07:56 PM
Originally Posted by SLOZ
Yes, you can.
Sweet, that's comin out when the dash does, hehe!
Old Oct 26, 2005 | 10:55 PM
oOoLy's Avatar
any pics of that bcm and locations plz ??
Old Oct 27, 2005 | 07:03 AM
SLOZ's Avatar
Behind the passenger side kick panel, little black box.
Old Oct 27, 2005 | 07:28 AM
y2khawk's Avatar
no BCM control over the windows, only the power locks. But you can fix that with a couple relays pretty easily.
Old Oct 27, 2005 | 07:42 AM
SLOZ's Avatar
Yes, I forgot the windows weren't controlled by the BCM, sorry about that, I have manual windows.
Reckless's Avatar
Super Moderator
My bad....I had a 1LE car with no power junk, so never had to worry about it
Old Oct 27, 2005 | 08:40 AM
1_Bad_LS1's Avatar
Lucky bastard!
