28x9 - et drag or hooser?
usually especially an auto car.I haven't run mickies in a while. I used to have a bit of a problem with rollout between tires when they were new...I would allway have to stretch one abit to get the roll out the same for both tires. Is that still an issue with the Mickies?
The m/t's haven't had any roll out issues for me ,but some people I know have had that problem.
The tire with a larger diameter or circumference will travel a greater distance per revolution.
This can be corrected by airing up the short tire to a pressure that will stretch it to the same(or slightly larger) circumference as the larger tire. Let it set a while and air it down to running pressure and it should hold its size.
Roll out is also used to measure how far a tire will travel from the staged position to the point that it breaks the beams.
Hoosier airs their tires up and writes the measument on the tire so you (or the warehouse/store sending them to you) can pick a pair that are close without having to mount them on your own wheels which is kinda nice.
