How do you have your ram air system set up on your drag car?
#43
hmm im considering fabing up something like sux2bu... ... i had nice gains from the FTRA as well, but i know there is more.. look at the vettes with the vararam picking up 3 tenths guaranteed or money back....
#44
I want to do it, but I'm concerned how it will effect my cooling and A/C operation. I have a black plastic "scoop" covering that area of my car, not to mention the windsheild washer tank (which I can ditch). Doesn't removing the black plastic shrouding reduce airflow over the radiator and condenser?
#45
i have one fan come on full blast at 160* and a second on a manual switch for when ever i need max cooling.
#49
I just made one like sux2bu has only thing is I did not cut the support just is close to the radiator about 1/2" away.Will this be okay ?Or do I have to cut the support?So it sits further from the radiator.
#53
SUX2BU has the Mike Hoffpauir mod. I miss him posting his old cam only times,that car is still impressive to this very date for what all it had.
I thought about doing the same thing and dumping the fast toys setup.
#54
So after reading this I got inspired. I used 4" pcv elbows from Home Depot and routed them from the foglight holes then I used a transition piece that squares it off and I ran, I'm embarrased to say, gutter drain up to the back of the airbox. I think it looks good, up to the gutter drain part
but I didn't have to cut the car up in any way and the gutter drain really fits well between the radiator-trans cooler and the frame support. Maybe I'll wrap the gutter drain part in heat wrap or something so you can't tell what it is.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#55
Got pics? I'd locew to see this setup on a TA
#59
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
Here is the most shocking update
NHRA Stock Eliminator Guys with 4th Gen Firebirds are a tenth and a half quicker with the flat hood and no Ram Air and a throttle body with no air cleaner or ducts or MAF.Lots of swapping there WS6 hoods dropping down a class and running faster
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
NHRA Ray
NHRA Ray
