Pre-loading rear sway bar
I want to clear this up for those people as well.
I have read Madmans posts about adding 15lbs to the passenger rear tire. In order to accomplish this he says that cranking up the drivers front spring will transfer weight to the passenger rear. I assume this is for us guys that don't have adjustable rears. I remember this from oval track racing.
I could do this with the front Hals, but I have the car sitting the way I want (I think).
In another forum someone posted the directions for adjusting a wolfe bar, but it was for a Mustang. (Same thing or not???) In short it says install the bar then jack up car until the front tires are off the ground two inches then tighten the passenger end link on the bar until the passenger door corner is 1/8" lower than the drivers.
Can someone please verify this for me and I will be on my way.
so I want to pre-load the factory bar.
I want to do this for learning purposes and I am not 100% sure on weather or not I want a drag anti-roll bar.
Any help would be great.
Thanks
Anyone able to help, or should I call Madman?
Thanks
Terry
do it but you would want to know the spring rate
and the lift force generated by the axle torque
reaction if you wanted to go at it like science. But
probably easier to cut and try an extra segment of
endlink spacer (or washers), keep adding until you
lose left tire traction instead of right. I don't think
a fixed preload poundage is going to give consistent
results from one car to the next. But you can find
the tipping point by enough trying.
Even blowing off the tires, the car stays almost perfectly straight. You can adjust the end links up or down to correct the car if it is darting to one side. My chassis guy told me that you always adjust the passenger side (once you have your basic set up in place). That way every one is on the same sheet of music.
The only drawback is that to drive the car on the streer, I remove one end link so the bar doesn't bind. I say it's a drawback only because I'm lazy and now I have to crawl under the car and reinstall the endlink when I go to the track or if I have a sudden need for traction on a saturday night :wink:
TWS, thanks. It is the basic set-up that is the most important factor. I like the sudden need for traction on a saturday night.
I've spoke to Madman about this via PM and the correct way is to disconnect the rear swaybar, get the 15lbs of extra weight on your passenger rear ( by jacking up your drivers front spring), then re-connect the bar.
This info has all been stated by Madman on this board over time, it's just that it is not all together in one spot. So I'm not giving away any trade secrets.
The key to re-connecting the sway bar or drag bar is that once the passenger rear is loaded with the extra 15lbs, is the fact that the passenger rear end link now needs to be SHORTER. This is the part people are missing.
You could also shorten the passenger end link if you didn't have adjustable front springs.
So that's it, finally I can go set the car up and sleep well at night.
Now the issue of getting my adjustable torque arm set perfect. I have it pretty good, but not perfect yet.
Nice car by the way. I was just checking out your website. Your car goes like mad. I noticed you purchased the Yank torque arm/trans mount bracket. I decided to get a spohn arm. Do you like the yank piece? It seems to be working for you. Did you get the pinion angle you wanted from that?
Terry
I don't think I noticed what cam you were running. I'm assuming you are going to a bigger cam; the T-Rex or is that the cam that ran the 11.0
Setup for 11.0 run:
Lunati 244/250 .615/.615 116+4 lsa
TCI 4400
3.73 gears
26" ET Drags
Dynoed 345 unlocked
New Setup:
T-ReX v.2 242/248 .608/.612 110 lsa
Yank 4800
4.30 gears
Fast 90 & NW 90 TB
28" ET Drags
Dynoed 381 unlocked before the 90/90
The cars suspension works like an "X". Cranking the drivers spring, adds to the passenger rear.
Bain, thanks for the info. That first cam you had was kinda huge. Any track results form the T-Rex?
vmax1500, that bars works awesome. Did you install it yourself? If so could you give us some install tips. like once you had all the welding done, how did you adjust it. Did you jack the front end up and then tighten the passenger end link? Any help would be great.
Thanks everyone
Terry
Andre
