What PSI for ET Streets??
With that being said, you didn't mention what size tire you are running.
I run a 26 x10.5 x15, my car weighs 3300lbs, so there web site suggest 16 psi and up.
I have run them at 19.5 psi and as low as 12psi. I dropped the pressure this low cause I was at a shitty hooking track. It worked and I pulled the wheels but I also pulled the wheels at 19.5 at a good hooking track. I cut between 1.64-1.68 60's with a 4000 stall and 3.23's
Keep adding a 1/2 psi until it stops hooking. Try to keep the tire temp within 25* of track temp. A huge burnout wastes the tires and won't necessarily make them hook any better.
good luck
maybe this is my problem
3600+ car I have run 8-9 PSI all the way to 12.5
1.70 60's is all i can get and thats with a two step at 5800
maybe try a higher psi
I allways wondered how you 1/4 mile people did it at 9 psi at 95 in the 1/8 my car is everywhere hahahaha i have played on other streets got up to 115 at 10 psi WOW thats a ride I will try more pressure next time.
