Drag Racing Tech
Rim Screws on Weld Aluma-Stars?
Old 07-09-2006, 08:35 PM
  #41
The Bull
DERTY's Avatar
You can get a 3rd party to anondize the rings fairly cheap in nearly any color imaginable if needed. As far as needing the bead locks. If you run a 1.35+ 60' it's not a big deal. I would get about .5" of wheel slip on the rim without screws. Right around there is a good time to start screwing them if they start slipping really bad. Screws can certainly hold the wheel where it needs to be. However, if you are looking for sub 8's on a drag radial or 1.1x territory 60's, the bead locks would be a touch much for the money. I will say that they did do wonders on Harlan's car in keeping the tire square to the ground. It's also a snap to put new tires on at the track without having to screw around with trying to unmount and mount the tires.
Old 07-10-2006, 06:58 AM
  #42
jshiver's Avatar
Originally Posted by Brady
I talked to David, he's getting gold anodized rings in the next couple weeks. That's the only color though.
Cool...That is just the color I wanted ...I'll give him a call this week and get mine reserved.
Quick Reply: Rim Screws on Weld Aluma-Stars?
