Drag Racing Tech
Do I have an 11 sec car ?
Old Nov 13, 2005 | 03:25 PM
Brianss1's Avatar
Default Do I have an 11 sec car ?
Just curious to know what you think about my set up here.I just bought the car with all the mods done to it already and will not be able to take it to the track till spring most likley.I was going to buy a bone stock one and build it myself but found this one and realy liked it.I know I will need some good drag radials or slicks.
01 ws6,silver,auto with a yank pt4000 stall,B&M trans cooler,DTS 12 bolt ,3:73,DTS support cover,complete BMR chrome moly panhard bar,adjustable torque arm,tubular control arms,driveshaft loop,strut bar,optima red top battery,k&n,slp lid,bg ram air mod,Mac headers,off road y pipe,magnflow catback,MSD wires,NGK plugs,smooth bellows,slp mass air flow,throttle body coolant by pass,160 stat,
2.02 1.575 manly racemaster valves with fully polished and ported heads Trend Fully hardend pushrods, COMP TI retainers, Dual Valve spring's
custom comp 228 236 588 578 114 ,ARP hardware,New Z06 gaskets.Around 400 RWHP and 360 torque on a mustang dyno .
Old Nov 13, 2005 | 03:40 PM
eric01ss's Avatar
sounds like u do go run it and let us know and get some m/t drag radials so u will hook
Old Nov 13, 2005 | 05:41 PM
mike c.'s Avatar
you should run 11's easy. but if you want to hook hard forget about the m/t radials try www.intercotire.com look at the m&h racemaster cheeter slick. i have got a best of a 1.34 60 foot on a m6 car.
Old Nov 13, 2005 | 07:03 PM
Brianss1's Avatar
I would think I would be in the high 11s.I am going to buy some good drag radials but I can not decide which ones.I would like to find the best tire for track that is street legal so I can drive on them to the track.I dont care how fast they will wear down but I want something that is safe on the street.
Old Nov 13, 2005 | 09:24 PM
SLowETz's Avatar
Sounds like 11's are in the bag if the car isn't bogged down w/a bunch of extra weight AND you can hook.
Fast on the track and safe on the street is an oxymoron. You WILL compromise "street manners" running a good track tire. You WILL compromise track times w/a "street" tire.
A Nitto would be your best of both worlds if you're not serious about track times. The MT drag radial is a GREAT track tire and not "too" bad on the street(wet pavement).
Just so happens I know where you can get a pair of MT radials if you're interested...
https://ls1tech.com/forums/lsx-parts-sale/408836-mt-e-t-dr-s-bmr-ta-bottle-opener-stock-stuff.html
Good luck!
Old Nov 14, 2005 | 06:32 AM
Brianss1's Avatar
How much of a differance is there with the Nitto and BFG and MT drag radials and what size tires are you running.Will I tell a noticable differance between the Nitto drag tire and my street tire in the 17 inch factory size ?
Old Nov 14, 2005 | 02:53 PM
mike c.'s Avatar
the nitto is a good street tire,hooks way better then stock. the nitto dont hook at the track that goods the bfg will out hook the nitto. the m/t radial will out hook both,but will not last long when driving on the street. it's best to have two sets of rear tires,street tires and track/street race tires. i have nittos for my street tire and m&h racemaster for track/street racing tire.
Old Nov 14, 2005 | 03:01 PM
Bryan @ Speed Inc.'s Avatar
looks like the car should go well into the 11's... i'd have a 4.10 in it if it was my choice, but it's not. get the car weighed, and run it. let us know your times, and raceweight.
Old Nov 14, 2005 | 03:42 PM
Brianss1's Avatar
I know 4.10s in the rear would give me a better start out of the hole but my gas milage would suck big time then.I will probaly go with the MT drag radial or BFG drag for the street in a 275 40 17 to match the front size.I do have an extra set of rear wheels in the stock size 17x9 I beleive.Mike C What kind of M&H tires do you have that are street legal ?
