Travel limiter info
I was also looking around for a set and I'm debating whether to fab up a set or buy a kit. Is this something universal where I can buy them anywhere? I ask because I saw a set on Wolfe's site and wasn't sure if they were built by Wolfe designed specifically for our cars, or just a kit they buy and turn around and sell.
If there's any other info you'd like to share, please let me know. Thanks in advance.
The car was set up as listed above on this launch. Pinion angle was -2
Tire pressure 11.5
Rear Hal S/A shocks at 7 clicks.Launch
Landing at the 60'
Ed
Ed
Ed
Wheelies get out of hand because the point of tip is improper for chaisis hook/power to weight distribution.
I met Dan Wolfe at SAR, and he said they like no more than 3.5 inches of gap between the top of the front tires and the bottom of the wheel well.
Mike
I'll try to take the pictures tonight. I have a friend that can tell me how to put them in a message here. I can't take credit for the limiter design. A friend of mine with a '97 F Camaro NHRA Super Stocker built by Mike @ MPR Race Cars. That car has limiters built like this. Cleanest setup I have seen. Maybe I don't get out enough. Hope MPR doesn't have a patent on them, I could be in trouble. <G>
Ed
Ed
Ed
The gap would depend on what you a trying to achieve and the amount you need to limit travel based on the suspension setup specific to your car. And if you are using lower limiters, upper limiters or both. example: If you are using upper limiters to overcome rebound unloading of the rear tires then you would have alot of gap. If you are trying to limit tip with just lower limiters then you would have less gap.
http://tulsaracewaypark.com/forum/in...;threadid=8124
A video of the car leaving taken from behind and slightly to the side of the car would be more helpfull. It's really had to tell what the car is doing from that angle and so far away.
Hope this helps.
Maggie Stewart,
Triple S & Stewart Racing
I do have scales (borrowed from one of my NHRA Super Stock friends), and a selection of springs. A good friend that runs an NHRA Pro Stocker disagrees with you on the front limiters, as do I. He thinks I need to cut my upward travel to about 1 1/2", which is the direction I was thinking. Too little travel and track irregularities can upset the car down track. I have about 30 years of this under my belt, but this is the worst wheel standing car I have ever owned.
I too have been at this a looong time, since the late '60s. Still learning though...mostly from some of the younger racers, lol
I'll add this: I no nothing of your set up and watching a video gives me little to go on as far as what you need to do. There are so many things that effect set up. One of the most overlooked is the mounting points of the cage which can have a little or a huge effect on how a car reacts to chasis tuning. So, I will not presume to know what will work in your instance but only offer sugestion based on my experience with similar doorslammers.
p.s. Oh, and yes, I agree some double adj. shocks would give you more latitude with fine tunning you setup.
Good luck with your set up, I'm shure you will get it worked out.
Maggie
Thanks, Ed
Hope this helps.
Maggie Stewart,
ed i have that vid hosted up that i emailed you
if you dont me posting it up i will
