Drag Racing Tech
10pt wolfe
Old Dec 7, 2005 | 11:40 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default 10pt wolfe
post up your pics and horror stories if any
Old Dec 7, 2005 | 12:08 PM
Matt D's Avatar
Retired Street Racer
I know Bill had problems with his not fitting. I don't think you can run the interior panels in the back seat area.
Old Dec 7, 2005 | 12:18 PM
Dan / Wolfe Race Craft's Avatar
Not fitting How? All interior panels can be used with our roll cage. They may need to be cut to fit the bars after installation, depending on which rear bars you get, but they are not eliminated.
Dan
Old Dec 7, 2005 | 01:19 PM
DopeFedZ's Avatar
I'm happy with mine. No horror stories for me but then again I had someone install it for me. By the way I just received their minitub kit and adjustable spring perches which are pretty nice pieces as well.
Old Dec 7, 2005 | 04:11 PM
Matt D's Avatar
Dan
I believe the installer was the one who messed up. I didn't mean any offense by it Dan. I have seen many of your roll bars installed with all the factory interior pieces.
Old Dec 7, 2005 | 07:38 PM
dopefedz post up pics
Old Dec 7, 2005 | 07:39 PM
i didn't know bill had one maybe he show me some pics too
Old Dec 7, 2005 | 08:10 PM
FastBlackTA's Avatar
Kit fits very well. I was very impressed.
Check sig for pics.
NOTE - The back bars are NOT wolfe's. We made ours slightly different as it suited what we were doing a little better.
Old Dec 7, 2005 | 08:14 PM
DopeFedZ's Avatar
I didn't install my interior panels again to save weight and because they were gray.
Old Dec 7, 2005 | 08:16 PM
Ron@Vengeance's Avatar
I installed my kit along with a local chassis guy.. He was VERY reluctant to use a "kit" knowing the typical quality of most kits... I had already purchased the Wolfe so there was no turning back... Long story short, he was amazed at the fitment/quality of the Wolfe kit... Said it was one of the easiest installs he had done...
FWIW, all panels will fit if the cage is done correctly.
Ron
Old Dec 8, 2005 | 12:30 PM
Tonyss1's Avatar
Default Wolf race craft Cage
The fitment was easy enough for a beginner. This was my first cage install I had it jig notched and tacked it in with a mig welder, then had a local shop tig it. I also installed the through floor subs and torque arm window net, Wolfs stuff is Top notch quality pieces. Email for pics my file is to big to attach. T
Old Dec 9, 2005 | 04:51 PM
ok send pics to xnoutics@excite.com
Old Dec 9, 2005 | 04:55 PM
so was it a pain to remove the dash for the front bars?
Old Dec 9, 2005 | 05:38 PM
Tonyss1's Avatar
Default dash
The dash took me about 1 hour to remove, the only thing that would make it much easier is if you have an extra guy helping you when it comes time to pull it out of the car after you unbolt everything. Pic sent
Old Dec 11, 2005 | 09:07 AM
so did you's guys buy it jig notched already? did it fit fine or did you notch yourself.
Old Dec 11, 2005 | 02:35 PM
DopeFedZ's Avatar
I payed extra for the jig notching. I asked the shop that did my install how much they would charge if it wasn't jig notched and it would have been alot more than just paying Wolfe to do it.
Old Dec 11, 2005 | 03:42 PM
waltsfastz's Avatar
Not to Kijack but is there anyway to put a 10 Piont in without removing the windshield? I too and going to try this this winter.
Old Dec 11, 2005 | 04:38 PM
Tonyss1's Avatar
Default 10 pt. wolf cage
I installed mine without removing the the windshield its a little tricky tig welding the front but it can be done. T
Old Dec 11, 2005 | 09:09 PM
GueSS Who's Avatar
I have installed 8 Wolfe 10pt cages. 2 being mild steele and the rest Chromoly. I have 0 problems with any of them. They fit like a champ and look really nice when done. You should get their threw the floor subframes at the same time. It really makes a difference IMO.
Old Dec 11, 2005 | 10:15 PM
so does the front windshield have to come out or no
