Drag Racing Tech
bumper support
Old Dec 22, 2005 | 12:06 AM
seppe855's Avatar
Default bumper support
any pics of bumper support just want to see what they look like.
Old Dec 22, 2005 | 06:25 AM
GM Muscle's Avatar
I suspect your talking about the impact bar?
It has a foam cover over it that supports the nose.
Old Dec 24, 2005 | 03:49 PM
theoldman's Avatar
Holy crap...how heavy is that thing?
Old Dec 24, 2005 | 04:30 PM
GM Muscle's Avatar
I believe it was 15lbs without the foam. If you cut the frame rails off that it attaches to that's another 5-6lbs.
Old Dec 24, 2005 | 10:58 PM
al's Avatar
al
Like GM Muscle said my scale read 14 lbs. for the impact bar and 4 lbs. for the foam. I rented a saw at Low`s and cut the frame rails that the bumper bolted to and saved 5.5 lbs. I also took off all the panneleing under the bumper cover and the washer fluid tank. I rigged up some aluminum 1 inch by 1/8 inch thick brackets to hold the top of the bumper cover up to fit flush with the hood and I slotted the bracket to adjust the gap between the hood and the bumper cover. I did not reuse the bracket that has the two hood levelers on it. I wish DopefedZ would post some pictures of his bumper. I mounted mine back up like he did his. Altogether I saved around 34 lbs.
Old Dec 24, 2005 | 11:13 PM
DopeFedZ's Avatar
Here is mine. May not be the best or look the best but it serves its purpose.
Old Dec 25, 2005 | 12:58 AM
chpmnsws6's Avatar
how fast have you gone with the bumper like that? any 150+ trips? i wondor how they do like that at high speeds. if they aren't to bad, thats a NICE idea!
Old Dec 25, 2005 | 01:24 AM
DopeFedZ's Avatar
Not quite 150 yet but I hit 148 I'm coming out with a new set up to get me deep in the 8's and I don't plan on changing those supports at all.
Old Dec 25, 2005 | 02:04 AM
chpmnsws6's Avatar
guess i know what i'll be doin!
Old Dec 25, 2005 | 10:51 AM
flyinZ's Avatar
Nice work Carlos...
What kind of wheels are those on the camaro, looks real nice.
Old Dec 25, 2005 | 12:23 PM
DopeFedZ's Avatar
Originally Posted by flyinZ
Nice work Carlos...
Thanks man. They are Weld Magnums.
