Drag Racing Tech
Launching a4 with drag radials
Old Dec 25, 2005 | 01:24 PM
foxtrotter's Avatar
Default Launching a4 with drag radials
So whats the run down on launching? I've heard a bunch of different opinions. Some say to launch in 1st and then put in drive. Some say to leave it in drive. Some say OD?
And what about heating the tires? I just got new BF DR's and supposedly these things dead hook with just a quick spin to clean them off....
And whats the deal with "flashing" is that just a quick pop of the pedal to downshift... I'm just new to this **** and trying to filter through alot of the info.
Old Dec 25, 2005 | 01:27 PM
offaxis's Avatar
What kind of converter are you running?
Different converters will require different launchs
Old Dec 25, 2005 | 03:10 PM
foxtrotter's Avatar
2.73, stock car w/stock converter
Old Dec 25, 2005 | 03:26 PM
offaxis's Avatar
With no converter just punch it! I dont think you will need to do anything special.
Old Dec 25, 2005 | 03:49 PM
c0ncEpT's Avatar
Heat the tires up with a decant sized burn out and Foot brake it as high as you can without cutting the tires loose and when it goes green stab it down to the floor. Its pretty hard to cut 2.73's loose with DR's in a pretty much stock car
Old Dec 25, 2005 | 09:20 PM
foxtrotter's Avatar
How many mph should i be getting.
Old Dec 26, 2005 | 10:17 AM
paper doll's Avatar
what are your exact mods?
Old Dec 26, 2005 | 10:19 AM
paper doll's Avatar
the mph you have in your sig is about right for that time low 14s is usually 95-100 in an a4, but once i got into the 13s my mph was around 100, and high 12s it was 108
Old Dec 26, 2005 | 03:07 PM
foxtrotter's Avatar
I have no mods, that time was on street tires. I ran once, and those were my times. So really it wouldn't had mattered how many times i ran, my mph would have been the same right?.....I just think maybe my cars a dog, i would think i would be atleast into the high 13's, it was about 50F out. Then again i was carrying my spare and jack, that shouldn't have costed me 3 tenths tho.
Old Dec 26, 2005 | 03:10 PM
foxtrotter's Avatar
Gradually roll into the throttle or jam it to the floor?
Old Dec 26, 2005 | 04:51 PM
Jassick's Avatar
this pretty much hit the nail on the head. you will have to experiment, as there is no perfect launch technique, diferent stuff works from different people.
Old Dec 26, 2005 | 05:33 PM
01_ram-air's Avatar
With the stock converter and ET Streets my 60' times got worse. Car hooked and kinda bogged. That's the problem that I see you having with some sticky tires, 2.73s, and stock converter. I would say to foot brake it up as much as you can and hammer it. Get a good TC and you won't have to worry about your 60' times anymore.
Old Dec 26, 2005 | 06:48 PM
foxtrotter's Avatar
That's exactly what i was worried about. What kind of converter would be recommended?
Old Jan 2, 2006 | 02:37 AM
RooRnZ28's Avatar
what about traction control? doesnt that kick in when the tires break loose? i dont know, but thats what seems to happen to me when my tires lose traction...the engine sounds like it wants to go, but something is holding it back
Old Jan 2, 2006 | 12:27 PM
01_ram-air's Avatar
I would say at least 3600, I'm running a ST Yank 4000 in mine.
Old Jan 2, 2006 | 12:29 PM
01_ram-air's Avatar
Take the traction control off.
Old Jan 10, 2006 | 08:46 PM
foxtrotter's Avatar
I was practing my launches on the street the other night and I was breaking the DR's loose. I was able to hold it to about 2000rpms, but now thinking about it, twas kinda cold that night high 50's...
Old Jan 10, 2006 | 10:19 PM
rufretic's Avatar
If you heat them up for a couple seconds, you will be able to dead hook with the bfg DRs by just slamming it off the line. I would guess you will bog though. I would see what happens with your 60' by getting the tires hot and then just floor it on the third yellow. If you bog and it brings your time down then try the brake stall method and then floor it. If you still bog then brake stall it again but this time just roll into throttle smoothly until your at full throttle. Your not going to have a problem getting those bfg's to hook at the track but you will have to figure out how the car performs the best.
Old Jan 12, 2006 | 05:49 PM
foxtrotter's Avatar
On my last run of the night lastnight i pulled a 13.945@100.5. Stalling wasnt really working for me, so on the last run I slapped it in D and launched off idle. Was plannning on leaving, so after putting my tires back to 30psi I decided to do one more run. So I think theres room for improvment because i couldnt get traction. The only problem I had all night was that I coudnt get my tires to smoke, I would try to burnout but my *** end would just swing sideways and I would start creeping forward. The brakes wouldnt hold. What kind of times will 100.5mph make?
Old Jan 12, 2006 | 06:35 PM
SSilverSSurfer's Avatar
heat em up like a john force burnout....***** to the wall...foot through the floorboard
