Drag Racing Tech
Starter for drag motor?
Old Jan 7, 2006 | 06:11 PM
speedracerz's Avatar
Default Starter for drag motor?
what starters will fit an ls1? i am biulding a 13.5:1 motor and not sure if the standard aftermarket (csi or powermaster) 168 tooth starter will fit.
who has messed with this and what were your results
thanks
Old Jan 7, 2006 | 07:17 PM
Tom the roofer's Avatar
POWERMASTER XS Torque for the ls1. I don't have a part number. I'm not sure if our sponsers carry them. I got mine from Summit awhile back. It's a heavy duty starter for sure Just ask for the above item.
Old Jan 7, 2006 | 07:53 PM
found it thanks
Old Jan 8, 2006 | 01:09 PM
1QuickT-A's Avatar
Cool.. I was wondering about the same thing yesterday..
Old Jun 28, 2006 | 12:57 PM
gman's Avatar
Are you guys having any clearance issues with the powermaster starters.
Old Jun 29, 2006 | 08:48 AM
ApacheDrill's Avatar
what did the part number end up being?
Old Jun 29, 2006 | 10:21 AM
93LS1RX7's Avatar
I have a 14:1 408 that I use the stock starter for, it turns it over no problems as long as the battery is good.
Old Jun 29, 2006 | 10:38 AM
gman's Avatar
pwm-9509 I found this at summit racing.
Old Jun 29, 2006 | 10:41 AM
gman's Avatar
My stock starter just **** the bed. I am just looking for a good alternative.
Old Jun 29, 2006 | 10:43 AM
Mine hasnt but i know its coming, once in awile when its been running awile and it gets hot.. it will just click over.. then when it cools down its fine. Same thing here 6.0 with a pretty big cam..
Old Jun 29, 2006 | 12:36 PM
DopeFedZ's Avatar
Anybody know what the stocker weights?
Old Jun 30, 2006 | 09:04 AM
93LS1RX7's Avatar
I am curious to see a side by side size comparision. I have VERY limited space down there and if that on is any bigger than stock I wouldnt be able to use it.
I would hate to spend $235 for something that doesnt fit with my headers
Old Jul 3, 2006 | 02:38 PM
gman's Avatar
Unless my scale is off the stock starter weighed around 7 lbs. and the powermaster starter weighed around 8lbs.
Old Jul 3, 2006 | 03:03 PM
gman's Avatar
Here is a side by side comparison:
http://i70.photobucket.com/albums/i9...tarters001.jpg
http://i70.photobucket.com/albums/i9...tarters002.jpg
Old Jul 3, 2006 | 05:28 PM
SlickVert's Avatar
What is the weight difference?
Old Jul 3, 2006 | 05:57 PM
direct bolt in?
Old Jul 3, 2006 | 06:08 PM
93LS1RX7's Avatar
Thanks man that helps a lot. Looks like I should be able to fit it.
Old Jul 3, 2006 | 09:28 PM
gman's Avatar
direct bolt in?
Yes it was a direct bolt in. It was tight getting it past the headers but it made it in. I only had one issue with it, after starting it up for the first time the starter ring gear wouldn't disengage from the flywheel. I then had to pull the starter and shim it with a supplied spacer. No big deal.
Old Jul 4, 2006 | 08:43 AM
Pop N Wood's Avatar
Man, this almost looks and sounds like the same starter
http://store.summitracing.com/partde...5&autoview=sku
Was $143 yesterday. Today I look and it is $159.
