Madman
I run between 4 to 6 in the rear with a straight Hal F M6 car, what would be a good starting point with the Hal or strange?
Thanks man
with your LCA kit does it totally eliminate the sway bar?
could you elaborate on the setup
Which kit I offer a couple???
which way do u adjust if the track prep is poor? Do you go stiffer or softer? I've heard too many different variations
Depends on which shock. On a single adjustable you would go softer. On a dbl. you would loosen the top(extension)
and does this apply to front and rear?
I stand corrected. Sorry Fireball.
Moving the front os the arm up will hit the tire harder BUT it doesnt lift as much weight. Lowering the arm will transfer more weight but doesnt hit as hard. If you move the arm up then you will need to run more air in the tires and run a different shock setting.
