Drag Racing Tech
Madman
Old Jan 25, 2006 | 01:13 PM
  #41
1BADAIR's Avatar
Do you recommend the TA to be high or low on a M6. The car is lowered too
Old Jan 25, 2006 | 06:59 PM
  #42
bearcat's Avatar
Originally Posted by MADMAN
Everyone elses T/A other than mine you can only adjust pinion angle. Usually I set them at 2.5 degrees down. I use the pinion only. The driveshaft is irrelevant for pinion angle.
wouldnt you have to find the angle the car happens to be sitting at when your adjusting the pinion angle? for some reason i see the angle bieng different if the car is sitting at an angle. thanks
Old Jan 25, 2006 | 07:01 PM
  #43
spanktu's Avatar
it is suppossed to be done on level ground
Old Jan 25, 2006 | 08:52 PM
  #44
1BADAIR's Avatar
when we do driveline angle at work(ford) we record frame angle,crank angle,driveshaft and pinion angle. I check the angle of the car(almost impossible to get level in normal garages,jack stands or ramps) and subtract or add that to the pinion
Old Jan 25, 2006 | 09:30 PM
  #45
speedo's Avatar
Going back to TQ arms there is three lengths/styles in my book..
Transmount W/relocation mount (long)
Tunnel brace mount (short)
Weld in mount... (mid)
Right now I run a trans mount arm on the trans. I can't be risk it on the tail shaft this year so I need to something to get it off the trans. I can't do the weld in style because I have Boxed subframe connectors.
I was partial to the "short" mount and sell my long one until I went to the track last fall and a guy with an F-body had a tunnel brace mounted one on his car with a full slick and skinnys and I had one 60' that was better than him and the others where the close all day. Almost the same mods done to both cars, but he had QA1 shocks all the way around where I am running a 275 nitto, stock shocks, street trim.
Taking it for granted that our setups where close, I think the short TQ arm hits to hard...?
How off am I...?
Old Jan 25, 2006 | 09:45 PM
  #46
JaSSon's Avatar
How off am I...?
Get a YANK crossmember that relocates the TA off the tail shaft. I got one and it works great. I cut mid to low 1.5s all the time with the stock TA at 3500 #s.
Old Jan 26, 2006 | 01:35 AM
  #47
speedo's Avatar
Originally Posted by fastlt1
Why subframe connectors first?
First time I ever ran my car at a 1/4 mile track with just headers and BF drags I came back from the first pass got in the staging lane and one guy pointed out that I best not let tech see my windshield was cracked....I was like cracked... Sure as Shoot I cracked it on my first pass ever with the car.
Subframes where my next mod.
Old Jan 26, 2006 | 01:43 AM
  #48
speedo's Avatar
I was looking at the picture of the Yank mount can you adjust the placement of the TQ arm holder like the BMR torque arm mounts?
Old Feb 8, 2006 | 10:43 PM
  #49
SPEEDYws6's Avatar
On mine you can not, but it wouldn't take much fabrication to make it possible. That will be one of my new projects.
Old Feb 12, 2006 | 12:01 PM
  #50
StangEaterSS's Avatar
I also have an M6 car which will be lowered soon. I just installed the BMR TA relocation crossmember. I put it in the 4th set of holes, starting from the bottom counting upwards. BMR tech line told me this is stock location. i was going to start here and test it at the track...but maybe this is not the best setting for my car. It will be on a 26x11.50 ET street. any input on this Madman?
Old Feb 14, 2006 | 01:42 PM
  #51
1_Bad_LS1's Avatar
what type of subframes for drag racing?
3 point or just the straight ones?
Old Feb 15, 2006 | 03:21 PM
  #52
I have the BMR straight ones. if you use those ones w/ the cross bracing go'n all over under the car you can't fit some types of aftermarket exhaust.
Old Feb 15, 2006 | 04:42 PM
  #53
chpmnsws6's Avatar
How off am I...?
tell him to stiffin up the rear shocks. its prolly shocking them so hard its bouncing and unloading
Old Mar 1, 2006 | 09:18 AM
  #54
DAPSUPRSLO's Avatar
I too have the BMR th400 member with the adjustable mount point for the stock length torque arm (random tech in my case). I started it at the top and am still wating on my motor so we'll see how it works when I get everything in the car and go racing. Anyone who has a similar setup and is running sub 11s post up how you've done with it and where it's setup, if you don't mind sharing seacrets that is. Thanks
Old Mar 1, 2006 | 09:24 AM
  #55
DAPSUPRSLO's Avatar
Moving the front os the arm up will hit the tire harder BUT it doesnt lift as much weight. Lowering the arm will transfer more weight but doesnt hit as hard. If you move the arm up then you will need to run more air in the tires and run a different shock setting.
In general, if you move the arm up, as I have, would you soften or tighten the shock. Car in question should be low 10s high 9s with 4.56 gears and a 30" (315/60/15) et radial tire. Thanks.
edit: Forgot to add car has adjustable lca's with re-location mounts, 3300lbs, 4.56s, with a 4000stall and 4.56 gears.
