Drag Racing Tech
New BIG GULP mod
Old Feb 12, 2006 | 11:16 AM
  #61
ls1 joe's Avatar
The nice thing about the big gulp is it was designed to help hold the bumper up. The way it is fabricated, the bumper does not sag at all.
Joe
Old Feb 12, 2006 | 11:45 AM
  #62
Bad Habit Bird's Avatar
Have you guys hooked anything up to see if the big gulp actually generates any boost at a given speed?
Old Feb 12, 2006 | 11:46 AM
  #63
Carbed4thGen's Avatar
Originally Posted by Ls1Joe
We are going to Houston Raceway Park tonight. We will be there at 4pm when the gates open. Should be a great night for racing
I will post results tonight when we get back.
Joe
Awesome how are u guys going to be conducting the comparison?
Old Feb 12, 2006 | 12:19 PM
  #64
TS6's Avatar
TS6
I don't have my bumper support in and my front end doesn't sag at all. Should it? I thought it was just to help absorb and distribute impact from a collision.
Old Feb 12, 2006 | 12:54 PM
  #65
00SS4780's Avatar
Cool, let us know how it does!
Old Feb 12, 2006 | 01:46 PM
  #66
ls1 joe's Avatar
I had a ram air before that was similar just not as large. I removed it and took it to Madman for this setup. I should be able to tell the difference right away. I will let you know. We are leaving out now for the track.
Joe
Old Feb 12, 2006 | 01:48 PM
  #67
00SS4780's Avatar
Cool, good luck man!
Old Feb 12, 2006 | 10:13 PM
  #68
ls1 joe's Avatar
Well we went to the track and first off, we are trying to get the new suspension dialed in so some of the data is not as accuarate as we would have liked. 1st pass off the trailer the tires spun really bad and my 60' was 1.82. That pass I went a 11.04@129.54mph. The MPH was very impressive for such a shitty pass. The next pass we adjusted the shock and raised the tire pressure and it was somewhat better. 10.55@129.69mph with a 1.59 60'. My best pass tonight was 10.53@129.79mph with a 1.47' so the numbers are not as accurate as I would have liked but from what I can tell, this thing picked up MPH on the big end by just looking at the 1st pass. I will be heading back to HRP on Friday and hopefully we will be working on the suspension a little more to dial it in and once we are completed, we will have 100% accuracy on this new mod for everyone. I also picked up more than 70lbs with all of my new mods from MADMAN which I expected to gain some but not quite that much. I guess I will be spending more money this week to get this monster light again.
Thanks,
Joe
Old Feb 12, 2006 | 10:36 PM
  #69
Hawk312's Avatar
What was your MPH before this?
Old Feb 12, 2006 | 10:52 PM
  #70
ls1 joe's Avatar
I went 130MPH at 10.30. What impressed me was the 11.04 (Shitty time) but my MPH was still there at 129.54. I know if I had a few more passes tonight I would have gotten into the low 10.30's or high 10.20's. The car is much better ( I did not log the passes like normal since the suspension was my main objective) but we are starting from scratch since we made so many suspension changes at once.
Thanks,
Joe
Old Feb 12, 2006 | 11:00 PM
  #71
SUX2BU's Avatar
Originally Posted by JL ws-6
A mini gulp thru the plate hole would work for me.... I'd be up for removing the bumper support to do it too, if somethign was made up to support it so it wouldn'st sag and look like hell like most of the cars I see with them removed.
Too bad madman is way the hell down in texas, if he was local, I'd drop my car off to have something fabbed up.
All of the cars i've seen with no bumper support don't sag.
Mine sags a bit cause it was in a wreck.
Old Feb 12, 2006 | 11:03 PM
  #72
SUX2BU's Avatar
Originally Posted by hourang
can the kit be made to use on a stock bumper and just use the 2 big holes for air? this has probably already been done maybe?
Quite a few guys have a set up like that. here's mine.
My dual 4" ram air helped out ALOT OVER my fast toys ram air. I gained 1 mph and .10 off my ET AFTER adding about 120 lbs. (this is over the FTRA).
Old Feb 13, 2006 | 07:40 AM
  #73
SlickVert's Avatar
Joe what was the DA yesterday and what was it on you 130mph best?
Old Feb 13, 2006 | 07:56 AM
  #74
King James's Avatar
http://www.mustangmods.com/data/5388...69413_3300.jpg
http://www.mustangmods.com/data/9054/ram_air_3.jpg
http://www.mustangmods.com/data/9054/ram_air_2.jpg
http://www.mustangmods.com/data/9054/ram_air_1.jpg
Man we need to all pitch in and buy you a real digital camera so you can stop using your phone to post pics
Old Feb 13, 2006 | 08:13 AM
  #75
hourang's Avatar
thats exactly what i want to do. any more details on this? a how to or something? curious how the tubes are mounted to the bumper and where or how to get the top plate that the tubes mount on before the filter. thanks
Old Feb 13, 2006 | 10:07 AM
  #76
ls1 joe's Avatar
TxCamSS had a weather meter and the da at 6:00 was only around 100 feet above. When I ran the 10.30 @ 130 the da was -700
Old Feb 13, 2006 | 11:04 AM
  #77
chrs1313's Avatar
I think you might have to loose your a/c to do this, correct me if i am wrong sux2bu
Old Feb 13, 2006 | 05:56 PM
  #78
SUX2BU's Avatar
I have one these are just old pics.
Old Feb 13, 2006 | 07:51 PM
  #79
SUX2BU's Avatar
I made the plate at work. and used about $25 in materials from home depot.
chris1313: i make the plate to where the holes are offset so you can run it with the a/c condenser. but it is close. I used to run mine with my a/c. i've made a few for friends and anyone hwho see's my set up and likes it. Everyone that has installed it says they love it. a few like my self felt a big difference when swapping it out for a "fast toys" like set up.
The only down side is you have to cut into your radiator support under the air filter for it to fit. but hey thats just less weight.
Old Feb 13, 2006 | 08:14 PM
  #80
speedo's Avatar
Can't wait to install mine in about a month here. Looks like a real nice piece so far.... probably will have some questions by then.
So far I have about 5,000 miles with the plate riding around in the backseat of my work car....
