Drag Racing Tech
arp studs and weld lugs
Old Mar 2, 2006 | 03:59 PM
hourang's Avatar
Default arp studs and weld lugs
ok search SUCKS, so i have to ask.
i have 15x10 and 15x3.5 weld prostars, with a moser 9" rear. what arp studs and which weld lugs do i need to pass tech? is there a sponsor i can get this from?
Old Mar 2, 2006 | 07:06 PM
NA$TY-TA's Avatar
OPen ended SST Lug Nuts........ I ordered all Mine from Thunder.....
Old Mar 3, 2006 | 07:56 AM
hourang's Avatar
ok well i found the studs on there, do i need 2.5 or 3.25 length? not running any spacers btw.
Old Mar 3, 2006 | 08:10 AM
hourang's Avatar
and as for the lugs, i have 2 choices from summit based on the info i have gathered:
WLD-601-1422
comes in set of 4 for $13.99 ea.
shank length: 1.379in
WLD-601-1452
comes in set of 5 for $9.99 ea.
shank length: 0.550in
looking up the rims on summit, it shows:
Lug Nut Shank Length (in): 1.300-1.380 in.
So i would be safe to go with the first option but its $69.95 as were the second one is $39.96. can i get away from using the .550in since its an OPEN END lugnut? or do i got to spend another $30?
please help i want to get these rims on.
Old Mar 3, 2006 | 08:26 AM
NA$TY-TA's Avatar
Call up Thunder Racing... they will know exactly what PT #'s you need to get... tell them what your doing...... let me put it this way.... i ordered all the Lugnut's washers and ARP studs and it was about $120.... Its your saftey.....when it comes to that a few dollars shouldnt matter....
Kyle
Old Mar 3, 2006 | 08:28 AM
hourang's Avatar
Kyle
oh i agree with you man, if it sacrifaces safety then i dont want it, i can pay the extra no prob, was just tryin to save a few bucks.
Old Mar 3, 2006 | 10:51 AM
1BADAIR's Avatar
I have 1/4 spacers and needed 3.25" to be legal.
The stud must stick out past the lug washer the same distance as the diameter as the the stud it self, 12mm or a 1/2inch if you use 1/2 inch studs
Old Mar 3, 2006 | 10:55 AM
hourang's Avatar
hrm, so i guess that means that it would need to be a min of 3" to be legal. ill get the 3.25s then. thanks!
Old Mar 3, 2006 | 11:08 AM
1BADAIR's Avatar
They won't look to good with the stock wheels though.
kevin and stenod gave me some tips though.
when using the stock wheels, use your stock lug nuts, then put some chrome acorn nuts on over the rest of the stud. that way all you can see is the acorn and the stud doesn't stick out.
Old Mar 3, 2006 | 11:14 AM
hourang's Avatar
good tip but my stock lugs are a closed end lug, i will have to use the weld lugs if i put my stock rims back on, which who knows if i will.
Old Mar 3, 2006 | 11:17 AM
Elite_Hot_Rod's Avatar
McGard makes the best open ended lugs, they don't corrode.
Old Mar 3, 2006 | 11:34 AM
gator's 99TA's Avatar
lol you dont live in the REAL south! down here in humid FL they ALL corrode within a few months. in door or left out it wont matter. mcguards last longer though. the cheapies will be rusted in 2 weeks.
Old Mar 3, 2006 | 11:41 AM
JMBLOWNWS6's Avatar
I went with ARP on the front 2.5 metric closed ends on the lugs. On the rear I went with ARP 1/2 studs with open end lugs. Kyles right it was about 130 shipped.
Old Mar 3, 2006 | 11:45 AM
hourang's Avatar
ok cool thanks guys i just went ahead and called thunder to order it, was more than i thought it would be but oh well.
Old Mar 3, 2006 | 08:05 PM
Racer8102's Avatar
I kind of have the same question, I posted in the tire/wheel section, I have 1/2x20 studs, 3.5 long, running weld prostars, I know I need the 1/2x20 open ended lugs, but what shank size and what length for the weld wheels.
Old Mar 4, 2006 | 11:18 AM
1BADAIR's Avatar
sst style
1.310'' long x .687'' dia. Shank Lug Nuts: Fits Pro*Star (96 series), Draglite (90 series), Rodlite (93 series) Wheels
Old Mar 4, 2006 | 07:08 PM
Racer8102's Avatar
Thanks
