Pinion angle and 60'
Is there an optimum pinion angle that seems to be the standard for the best 60' times? I have had mine set at -3.5ish and may try something different. best 60 with the 325 Mt's is in the 1.7 range. I must do something to hook on these tires.
-2 degrees of pinion angle but again its all in how precise you and your angle gauge are. the difference b/w +2 and -2 degrees is pretty big IMO on how the car launches. make sure you are measuring it correctly.
also you have an A3, are you launching on the transbrake? you should be hammering the tires off the footbrake. the transbrake is pretty tough with the stiff sidewall drag radials.
