Transbrake and two step
12 volts to the transbrake button. Then Y off to the trans brake and 2 step with a relay activating the 2 step. I believe its the white and grey wires that negativly activate the 2 step. Just run those thru a relay that is activated by the transbrake button. Thats the way I remember it. It's been awhile. I now have an aftermarket EFI with the 2 step built in.I bracket race with an NA motor and I use my 2 step for consistancy. I can set the launch rpm and when the lights start to come down I mash the pedal to the floor. I don't need to watch the tach to keep a constant rpm. Besides that its a blast
Like stated below, I do not want to have to watch the tach to get my RPMs in the right place.
I have heard the same thing however a 2-step has got to be be better for the trans/converter. Instaed of using the 2-step to limit engine Rpm you are using the converter/trans....that's can't be good.
