Drag Racing Tech
5 point Harness
Old Apr 25, 2006 | 11:43 AM
stageit's Avatar
Default 5 point Harness
How are you guys attaching your Harness to the roll cage? What are the rules on this for 8.50 and slower. What size bracket do i need to weld to cage to bolt Harness to?. Any pics? Thanks for any help
Old Apr 25, 2006 | 11:47 AM
ls1mongrel's Avatar
Ive seen some that wrap around the bars, but not sure what the rule is, our track is very relaxed on rules !
Old Apr 25, 2006 | 11:52 AM
Racer8102's Avatar
I wrapped mine around the cage and used the metal lock down straps that came with the harness to secure the ends to the cage.
Old Apr 25, 2006 | 11:58 AM
stageit's Avatar
So yours doesnt bolt to the cage with 1 bolt? you have 2 straps going to cage? I have 1 bolt that goes to cage but not sure how thick the bracket needs to be and where to mount it. Maybe 1/4in thick?
Thanks
Old Apr 25, 2006 | 01:19 PM
Racer8102's Avatar
No mine does not bolt to the cage. Both shoulder straps wrap around the crossbar and have a metal slip lock that holds them tight, and the other three points bolt to the floor.
Old Apr 25, 2006 | 02:01 PM
stageit's Avatar
Ok, thanks
Old Apr 25, 2006 | 02:07 PM
SiL3NtXWS6's Avatar
The tech at my track told me to wrap it around and i would be fine.
Old Apr 25, 2006 | 03:03 PM
1_Bad_LS1's Avatar
x2 just wrap it
Old Apr 25, 2006 | 05:43 PM
stageit's Avatar
I cant, mine looks like this
Old Apr 25, 2006 | 06:19 PM
ALL UC2's Avatar
i think 3/16 is plenty. i have seen one that just drilled a hole through the bar and stuck a bolt all the way through it. dont know if it would pass tech though.
Old Apr 25, 2006 | 07:09 PM
JPMuscle's Avatar
It would bolt to the floor Right?
just get a Grade 8 bolt a big washer and some red Thread locker and you should be fine.
-john
Old Apr 25, 2006 | 07:26 PM
SiL3NtXWS6's Avatar
I had mine orignally bolted to the floor where the stock seatbelts go in the rear and and it did not pass tech
Old Apr 25, 2006 | 07:29 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
NHRA rules are bolt in....[ bolted in floor, and on bar ].....you can get away with whatever - wherever though....no wraparounds allowed in the big-leagues.....
Old Apr 25, 2006 | 08:57 PM
stageit's Avatar
Thanks everyone for the help. I just welded a 3/16 tab off the back of the cross bar and bolted the seat belt to it.
Thanks
Old Apr 27, 2006 | 08:35 PM
SUX2BU's Avatar
By big leagues do you mean 8 sec cars? i have mine wrapped around, but my car will probably only eventually go as far as low 10's high 9's.
