car hooks then unloads
i have stock struts and springs in front, swaybar!
back i have ajustable lower control arms, and panhard and bmr t/a, stock springs and kyb ajustable shocks(i think they suck but they were there when i got the car)
car throws the weight like a ****, pulling the wheels a few inches off the line, then about 20 ft out breaks them loose. best 60 ft i pulled was a 1.65. i have a 4000 stall with a th350. and i could leave off the footbrake at 3200, but with the 1.65 60 i left at 2000rpm. what do i need to do to keep it from breaking loose 20ft out or so??? track wasnt preped that good though.... i am guessing i need some qa1's up front cause it starts spinning when the frontend starts to settle. let me here some suggestions. i know this think can 60 better than that
i did a search but couldnt come up with anything. car is cam only with 4.10 gears. if it matters.
One thing you could probably do is get a set of adjustable shocks in the front, to slow down the weight transfer to the rear, this way the car will not experience the quick setdown after the initial launch and cause the car to bog. Personally, I got a set of hal R series for the front, this way I can control how fast the nose comes up, and regardless of how the car picks up, it will always set back down realtivly soft.
Unfortunately, I'll never know if that would have solved the problem, as I had a bottom end failure that prompted a new iron 402 motor to be built for the car, and I was planning on a th400 conversion already anyway, with a 4500 converter, fguring that would probably fix my inconsistancy and get the launch down, and eliminate the weak ink in my driveline at the same time.
does anyone think that with a whole set of qa1's i will still need an airbag?
Also, do you have relocation brackets on your car/ what's the full suspension consist of?
If you aren't running a 28" stiff side wall slick you might consider it. Goo luck and keep us posted.
What is our full chassis and tire setup? I'm no expert, but I'm sure there's plenty of people with experience on here that can steer you in the right direction.
front is all stock except swaybar removed.
rear is
adj. lower control arms
adj panhard
bmr body mount t/a
removed rubber spacer on top of spring
kyb adj. shocks.(i know they suck but they were there when i got the thing.)
wheels and tires
pro stars with 165r's front and 26x10.5 et streets out back with no tubes. hooked best at about 12 psi
cam only(t-rex), full bolt ons, th350 w/ 4000 stall, 4.10 gears
i honestly think that i just need a set of qa1's to solve the problem. it was unloading when the front came back down a few feet out.
as for the tires, i have a 12 bolt that i am going to put in the car but dont have the money for gears and bearings right now, so i am still on the 10 bolt. i had these tires in my garage and figured that they might help save the 10bolt. i am planning on running 275/60 hoosier drag radials with the 12 bolt.
i just have the stock sway bar out back. car doesnt feel loose at the top end, do i still need a airbag or not??
