anybody running a vacuum pump with a race EWP?
Originally Posted by TOSTO RACING
Did you ever see mine John . I can get another bracket like mine and you 'll be good to go if you have the aerospace vacum pump. Let me know.
pm
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It depends on your motor. You can regulate it. I 'm pulling between 10 and 12.
If I don't regulate mine it pulls 15.
I would like to see a pic of your setup as well.. I would like to get a better looking bracket then the one I have..
I'll see if I can get some up it works perfect. I used the asp pulley and modified the crank pulley for the vacum pump its slick . You will have to make a bracket to mount it where the ac used to be also.
Let me get a camera here and I'll get some pics.
really? i could have swore you were using an ATI dampener.
Originally Posted by Z8'S
Bracket that mounts in a/c location.
http://reichardracing.com/LS1_vaccuum_pump_mount.php
I was kind of leary about using an ASP dampener on my 408, but if Tosto is having good luck with his then I see no reason why I shouldn't try the ASP on mine. I REALLY do not want to spend $500 on a balancer when I can get the ASP for $175 from a local shop..
#32
I am running the asp pulley,the sfi one. Thanks for posting that pic John.If you guys want some brackets pm me for pricing and I'll have my buddy make some ,he made me one and kept it all to make more if you guys want some.
As far as the front pulley(mandrel) you will have to have a machinist or someone re drill the holes to fit the asp pulley thats how mine is and it has been flawless for me.
Pm me on the brackects guys.
My tires are 28x10.50x15 stiff sidewalls M/T slicks
#33
As far as the front pulley you will have to have a machinist or someone re drill the holes to fit the asp pulley thats how mine is and it has been flawless for me.
PM Sent on the pump bracket!
#35
I'm not sure I do know the aerospace mandrel and asp pulley are different.
#36
1quick, from what i understood from what was posted previously in this thread is that you can run the mandrel that you already have, you will just have to drill new holes in your ASP pulley and thread them. that would be something very simple for any quality machine shop to do.
#38
Well ,we left the asp pulley alone and drilled the mandrel to fit the holes on the asp pulley.
well its not even close to matching up.. TOSTO you have a PM..
#39
I have some pictures of a bracket that a guy made to be used with the Aerospace pump. It mounted where the AC went, with a custom bracket. I dont have the pics handy as they are on my other computer, but I will post them up tomorrow hopefully.
BTW, if anyone is interested in an Aerospace vacuum pump with the mandrel drive, I have one for sale here Vacuum Pump for sale
