Questions About 29.5x10.5ws
#41
Originally Posted by Big Mike
I am stock suspeneded! All mounts are in factory locations!
Hmm that's interesting..I didnt' think you could narrow that rearend that much without running into the lower control arm mount. Or did you just move the outside mount in a little?
#42
Originally Posted by stressfulcar
...I will also be doing the mandatory adjustable spring mount and offset lca's....
i can imagine it would be a LCA with a bend in it to clear the tire and meet the factory floorpan rear LCA mount, but ive never seen or heard of one.
have any pics?? id imagine it would have to be pretty beefy to keep from flexing, right?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#44
Originally Posted by MrDude_1
whats a offset LCA look like?
have any pics?? id imagine it would have to be pretty beefy to keep from flexing, right?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
It's not a bent piece. Instead of mounting it square in the middle of the mounts a spacer is used to move it towards the inside of the car therefore freeing up an inch or two of space
#48
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
So you then inturn moved the rearend mounts over to accomodate? or does the lower control arm just runn on an angle? excuse me if I seem a bit confused here
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#49
Originally Posted by Carbed4thGen
So you then inturn moved the rearend mounts over to accomodate? or does the lower control arm just runn on an angle? excuse me if I seem a bit confused here ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The rear end mounts for the LCA are obviously moved because the rear is shortened. The LCA do run on a slight angle off the rear to the body mount if you can see in the picture.
#50
Ok it's all understood now haha thanx
#52
Originally Posted by DAPSUPRSLO
Big mike, are those mounting provisions for a 4 link on that rear, just not being used obviously. that's a super trick setup you've go there!!!
I think those are for wheelie bars cause if I'm doing this correctly the 4-link brackets should face the other way
#53
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#55
looking through the pics of mikes car, I dont see any of the lower arms..anyway though, they are in the stock front mounts, offset to the inside of the car..they are in the factory mount ... and like he said the mounts on the rear were obviously moved in.. I just noticed, you can actually see in the pic he posted that the arms are in the factory mounts, just offest all the way to the inside...
jay
jay
#56
I ruin the end of films...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I debated on moving mine to the inside of the frame. I didn't want to get any flack in the S/S classes, so I went w/ a .25" spacer and moved my control arm as far in as I could.
Nice rear btw (not often I say that to another guy
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#57
#58
Moser told me..that leaving EVERYTHING in the "stock" location...All you can narrow is 3.5" per side....I don't think I can fit a 12" wheel and keep it "as tucked" as the 10" wheel.
So...what you are saying Big MIke...is that if you were to measure from the center of the pinion to the inside edge of the closest lca bracket...It would be less than the measurement on a "stock width" rearend...right?
This is pretty much the same set-up Big Rick and Wormboy have on their cars (in texas) I think.
#59
yes ....
#60
Originally Posted by mongse
I could see this being contested as a stock suspension setup. Granted, moving the LCAs in doesn't affect how the car hooks (other than the fact that you can fit a fatter tire), but some people (i.e. those w/ slower cars) just need a reason to bitch. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
fyi, mikes arms are in the factory mounts and offset to the inside..there not on the inside of the frame
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
jay
