Drag Racing Tech
help figuring da
Old Aug 2, 2006 | 10:18 AM
s346k's Avatar
Default help figuring da
i was hoping to figure the da on some runs i made last weekend. can someone help me? searching for "da calculator" brought up 473289 threads with nothing about da mentioned in the title.
7-29-06
2:30 pm
47610-9150 zip code
elevation 385'
92* / humidity unknown
thanks for any help offered / applied.
Old Aug 2, 2006 | 10:52 AM
Ranger's Avatar
King of the radial tires
When I began drag racing, I tried using calculators on the net, powered by local weather reports, also from the net. That approach will yield very gross estimates of the actual DA. And the result will vary substantially from racers using hand-held weather stations, such as those made by TAG.
Gotta remember that most net formula assume the input for barometer is in "absolute pressure." That number is diiferent from the "barometric pressure" given by weather site and TV.
Bottom line is that if you want to know the DA at your track, you need to buy a hand-held weather station. Even then, those instruments need to become acclimatized to local conditions. Mine typically needs 15 minutes in the shade before is stabilizes and provides accurate reading. Can't just keep it in the car and then hang it out the window for a quick reading.
Ranger
Old Aug 2, 2006 | 04:07 PM
jay_99z's Avatar
Here is a good site for historic weather data. http://www.wunderground.com/history/...q_statename=NA
And the calculator. http://www.csgnetwork.com/dadtcalc.html
ET correction http://www.modulardepot.com/density.php
