Pics of 315/60/15 MT DR's with mini-tubs
#63
Originally Posted by 9sec93
thats why i am running a drag radial. i am gonna drive this thing quite a bit.
How much tubing did you use, granted the backhalf kit came preassembled. Im thinking 120 ft will be more than plenty. were gna do a full cage and back half similiar to yours with all the extra bracing.
-john
#64
I have a question for those with the minitub. Can you keep your back seats after you install a minitub. I want to go the m.tub route but I also want to keep the back seats in the car as well.
#66
#67
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#69
I dont think so, my latches at the top are gone, and where they mount and pivot at the bottom. How much tire do you need? A 325/50 will fit, but will stick out of the fender about 1.5 inches.
David
#70
I haven't decided on what to do yet on what size tire I want. If I could minitub and keep the rear seats I would just so I could have more backspacing. If not I'll go with a 315/325 drag radial on 15x10 rim with 5.5" backspacing and roll the fender lip. This car is going to still be driven on the street so I may have to stay away from the minitub.
#71
-john
-john
#74
https://ls1tech.com/forums/drag-racing-tech/566035-attn-madman-picts-25-2-stock-susp-lots-picts.html
check this out jays car on ground with 315, just got it certed today for 25-2 now if only he could go that fast
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#75
Originally Posted by SMKN TA 95
This past week I picked up a set of Mickey Thompson ET street radials for the Formula. I picked them up for a great price, plus I have researched and they work as good as a full slick does. Figured I would give them a shot.
The tire size is a 315/60/15 (30"x13.5"), on a 5.5" backspacing wheel, car has mini-tubs and a narrowed Moser 12 bolt rearend (2.5-3" per side).
A little trimming was required, but that was already done by NRC-Motorsports when the car was built.
I went with this size tire so I can keep the 4.56 gear in the car while I spray large amounts of nitrous
More pictures can be found at this link http://www.9handsracing.com/brian/Tires/
![](http://www.9handsracing.com/brian/Tires/DSC01161.JPG)
![](http://www.9handsracing.com/brian/Tires/DSC01148.JPG)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#76
Originally Posted by NRC-Motorsports
jays right you should sell me that back and i can put my 572 turbo engine in there
bob
I dont know about that
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Ive got alot tied up in this thing, plus I have alot of parts waiting for the motor.......I think I'll keep it for now
On another note, being that the rear pro-stars on this car are 5.5" backspacing and being that you originally built the car, would a 5" backspacing wheel fit with this tire.
The car isn't at home right now to look at, but I thought I would pick your brain if you can remember when you built it and what kind of clearances you had(what about Jays car?)
#77
i already had a 6 point in the car but with how the cage goes through the firewall and deletes the front strut towers i think i used less than 120 ft. also my backhalf kit was not pre-assembled but it did come with the tubing. so yea, 120 ft. should be plenty. good luck and just remember, measure 5 times and cut once.
so you built a tubular front end or did you just tie the tubing into the origianl towers like most guys do, if not I need to see some pics of that
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
-thanks,
-john
#80
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
jay
