If Chromoly can be Mig welded, Why all the Fuss?
I spoke with three welding shops and they all told me the same thing, Chromoly can be mig welded providing you have the right wire, easy enough. If thats the case why does every thread that ive read and cage company states out right that Chromoly cages must be Tig welded. Is there a specific reason for this the only thing i could come up with is NHRA tech mandates that chromoly be tigged. If there is no structural integrity to be lost with the mig approach and tech mandates it be tigged why?
Thanks,
-john
Thanks,
-john
Thanks,
-john
Thanks,
-john
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
so therefore mig is sufficient for mild tubing because the wall is thicker?
-john
-john
ps, we need an engineer to give the technical reason,lol
so aside from asthetic purposes a properly prepared and executed MIG weld with chromoly should be comparetively strong and suitable for the majority of Drag racing applications, its just not ideal?
-john
-john
-john
-john
no, thats what they are saying, when you mig weld the moly you can overheat it and make it brittle.
6 & 8 Second Club
All great answers, plus better & more consistant penetration.
I think I remember long time ago hearing NHRA's reason had something to do with SFI's concern for the heat, and more control with Tig welding, a good weld will be stronger than the tube.
This may be a very broad generalization, so bear with me.
I think that what may be part of NHRA's mandate for Tig on 4130 is this.
Any Joe Schmoe can pick up a Mig and throw down a bead. That doesn't mean it's a well executed bead with proper penetration and no cold lapping, etc. With Mig it feeds wire weather your technique is correct or not and too easy to get a cold weld with little or no penetration, yet look like a nice bead profile. It has taken me many years of critiquing my own mig welds and really trying hard to watch very closely at what I'm doing while welding with Mig.
Generally with Tig, due to the increased difficulty in performing the process, more often than not you'll see Tig done in shops doing specialty and high quality work. Tig is much easier to see your weld puddle and manipulate it before adding filler material. I think NHRA feels that if you have the skills to wed with Tig, your more than likely gonna get the proper heat and penetration due to the increased skills required to perform the weld process.
I could be wrong, but that's my take on the requirement for the NHRA Tig mandate for chromoly.
BINGO!
It's very hard to control the heat effected area when mig weldind chromoly. As you stated it is difficult to see what is going on in the puddle with wire squirting out continually...Can good cm welds be made with a mig? Absolutely.
There may be changes coming about in the near future that will allow for easy & excellent welds on CM with a mig welder. The bi-metal, metal core alloy, and specialty flux-gas wires look to be very promising.
Shoot, I remember when TIGing chromoly was questionable. The GAS welding people certainly made some good arguments against it... Just be glad we don't have to GAS weld our cages!
