325/50/15 mounting on a camaro
#44
i had a 315/35/17 bfg drag radial wihout touching the bumpstops. but i had to always jack the rear up by the rear end.
If you wanted a dr on a 15'' rim your go with a 275/50/15 or a 275/60/15
#45
Originally Posted by SiL3NtXWS6
the work shown in the picture was what it took to barely fit the 325's. I then went back and cut a lot more of the bump stop area out where out, following the red half circle.
The oval is where you need to hammer a LOT. I tried an air hammer, which did NOTHING. I used a normal hand hammer, then i brought out my big sledgehammer to finish it off.
I used metal snippers to cut the rear fender where it says "TRIM"
#46
I had to cut mine out like that too. I run a 275 60 15 but my 12 bolt is shortened 2.5 inches on each side and I run a 15x10 with 5.5 BS.
Double adjustable LCAs work like a charm. I fit a 28 inch tire without cutting or trimming the wheelwell or bumper cover.
