"RACE" Alternator Bracket
You are correct.. No power steering, no a/c, and electric "race" water pump.. I don't want to buy the BMR bracket because I will have to drill and tap the block for it to work correctly. I think I could still use it without drilling the hole, but if I'm gonna pay $130 for it I want to use it like I'm suppose to.
Im a bo-bo...
This is the best pic I could get without taking everyting apart and I don't have time for that but I did go out and take the belt off and take a pic. I'm ready to put the car on the trailer.
Anyway, I'll do the best I can.
There are two bolt holes in the tensioner pully bracket. You can see in the pic I used the bolt hole to the left and the bolt hole to the right is not used.
Set the tensioner pully bracket in position behind the bolt hole in the alternater bracket that was once used for the idler pully as shown in the pic above. Put the bolt thru the 2 holes mentioned above. DO NO TIGHTEN the bolt at this point.
Let the tensioner pully rest on the alternater bracket and you will see the area on the tensioner pully that will need to be removed, ground off for clearance. That will take about 15 minutes or so its no big deal. Grind enough off so the right bolt hole area of the tensioner pully rests squarely on the alternater bracket. Tighten the bolt in the idler pully hole.
Once you find the right belt size, Mine is a 37" belt with my crank pully, put the belt on. Now you will see the belt is going to rub on the lower long bolt head that holds the altenater in place. Take the belt back off and grind one side of the bolt off till it doesn't rub anymore. You can see this bolt in the pic.
Thats it your done. The tension on the belt holds the tensionor pully in place so you only need one bolt.
Good luck
