TH400,3.42's& 26" tire to small?
Heres the deal i'm in the process of swapping to a TH400.Car has 3.42's in it for a rear gear.Car has a Gm Hot Cam and a dualstage nitrous setup for a toatal 250 shot.Will 26's be to small to make it thru the traps,rev limiter set at 6800 rpms.
BTLFEDSS
BTLFEDSS
IMO. Try the 26" 1st before you buy new tires. BUT my guess is you will be finishing at barely 6,000rpm crossing the finish. I believe the 28" will serve you better - I'll also bet you that 130 is a very, very low mph estimate. With my stock engine, with h/c and up to a 200 shot, I ran 4.30's on 30". Ran a best of 10.08 at 134. Was going to move to 3.73's and do 250 shot (out of the hole - single stage) before the SS decide to drag its bumper.
Use your Transbrake to cut off the nitrous until you release it upon launch - give a 100 shot out of the hole, 150 after 2nd gear shift. You'll be in the 10's
David
David
