Going To The Track For The First Time.....
here are some questions:
what PSI should i set my rear and front tires at?
I ahve a little bit of a slipping problem from the clutch. so what RPM should i feather the clutch out of the hole at?
What do you think i will trap? And what speed? i think 13.4 @ 106 with a 2.3 60'
What else should i know or expect?
this will by my first car i ever own to get in to the 13's god damn 97 Mustang GT i had every thing on that car known to man N/A of course and still could not brake 14. My best time was a 14.01 @ 96.28 with a 1.87 60'
yes it was a 5 speed too...wush me luck and give me some input..
I can tell you that you won't run a 13.4 @ 106 with a 2.3 60'; Now, you might run a 13.4 you might run 106 mph and you might run 2.3 60'...you just won't run them all at the same time. I'm auto, so a little different but I went 13.5 @103 on a 2.0 60' when i was stock on street tires. Good luck, have fun. Let us know what you ran.
wow, that is weird is he A4 or M6?? if M6 that has a lot to do with it... but i am going to US41.. i guess i will have to see what happens when i go...
we are going this sat! you should come
Her are the resluts.. See sig for mods.. This was on Street tires 32 psi
Run #1
Reaction.......... .7501
60 ft.......... 2.2009
330 ft.......... 5.8219
1/8 ET.......... 8.7507
1/8 MPH......... 84.44
1/4 ET......... 13.3109
1/4 MPH........ 108.20
Run #2
Reaction.......... .6711
60 ft.......... 2.3308
330 ft.......... 6.0558
1/8 ET.......... 9.0018
1/8 MPH......... 83.96
1/4 ET......... 13/5819
1/4 MPH........ 106.88
Run #3
Reaction.......... .6180
60 ft.......... 2.2237
330 ft.......... 5.9270
1/8 ET.......... 8.9149
1/8 MPH......... 83.18
1/4 ET......... 13.5109
1/4 MPH........ 107.47
talked with some guys, if i had a 2.0 60ft with LCA and torque arm i would have been a 12.7 pass with the MPH that i was trapping.. Not to bad.. next mod is torque arm, LCA 12 bolt with DRs...
see ya sat
