Drag Racing Tech
Anti_roll Bar?
Old Oct 29, 2006 | 01:31 PM
Hot Copper Z's Avatar
Default Anti_roll Bar?
Which one is better?The Wolfe looks pretty beefy.I've got all BMR stuff so far and had good luck with it.1.45 short times on motor with a lot of body roll and right side setting down on slick a little.Can't spray it until I get a anti-roll bar of some sort,should be some low 1.30's or high 1.20 60fts with spray.Any suggestions would be appreciated.
Old Oct 29, 2006 | 05:44 PM
sprydncamd ta's Avatar
i bought the sphon bar because i read the wolf one makes noise when you drive on the street unless you disconnect one side
Old Oct 29, 2006 | 06:43 PM
1QuickT-A's Avatar
I'm running the BMR Extreme Duty bar and it seems to work great so far.. You definatey do not want to run the Wolfe bar if you plan to do alot of street driving. Its the best for a track only car, but its stiff as hell and very noisy on the street from what everyone says..
Old Oct 29, 2006 | 10:28 PM
94z28L's Avatar
i have the spohn and love it, the spohn and bmr are nearly identical too
Old Oct 30, 2006 | 03:49 AM
tektrans's Avatar
I have the Spohn. Works great down to 1.40 60's. Low 1.3's and 1.2's I don't know cause I'm not that fast.
Old Oct 30, 2006 | 03:37 PM
sickss228's Avatar
I was thinking of getting the Wolfe but I still drive on the street alot, so I think I'm going with the Sphon instead.
Old Nov 11, 2006 | 12:52 AM
Jersey_TA's Avatar
I've got the Spohn bar and I love it.
Old Nov 12, 2006 | 09:40 AM
mike c.'s Avatar
i have the bmr and its been great. quiet on the street and my 60 foot went from a 1.50-1.49(ish) to a 1.44-1.42 being my new best.
Old Nov 12, 2006 | 12:09 PM
Matt D's Avatar
Retired Street Racer
Spohn here. No complaints.
Old Nov 12, 2006 | 12:23 PM
gator's 99TA's Avatar
BMR or Spohn drag bars for a streetable car. Wolfe/Billingsely for a race car. untill you start getting into the 1.29 60' i dont think the wolfe is needed
Old Nov 12, 2006 | 01:31 PM
ls2 bait's Avatar
i ended up going with the spohn 1" bar and i didnt notice one bit of diff in road noise. its not as stout a peice as the larger bars but im sure noise would be comparable.
Old Nov 12, 2006 | 08:13 PM
BKHAWK1's Avatar
i have the sphon and you can see my 60' times in the sig. that is on DR's to.
Old Nov 12, 2006 | 09:51 PM
94z28L's Avatar
now when you guys are refering to the spohn bar i see a 1" rear bar and the other posts dont specify, i personally have their drag specific bar, which one do you guys have?
Old Nov 13, 2006 | 04:14 PM
BKHAWK1's Avatar
its been awhile since i installed mine. i have the one that has adjustable hine (sp) joints on both sides. it must be 1" b/c it is pretty hefty. it works like a champ, the car leaves striaght with the front wheels in the air.
Old Nov 17, 2006 | 07:45 AM
I ordered the BMR Xtreme duty,thanks for the input every one.
Old Nov 17, 2006 | 12:41 PM
94z28L's Avatar
if it has the heim joints on the end links its the rear drag bar its 1 5/8" diameter
