Simply question about the traps
What I am asking is this: How many feet at the end of the 1320 is used to determine the trap speed?
More info can be found here: http://www.staginglight.com/guide/defns.html
I think there really can be measurable differences in time slips between tracks. Only thing I can figure is minute differences in photo cell placement, be it distance (length) from each other, or even possibly the height at which they are mounted, or even the amount of crown the track surface has which affects the height and rollout. I'm refering to all photocells, not just staging beams. We have two tracks I run at and on is at 525' elevation, the other 325' elevation. The first is a good tenth to .15 in ET slower as well as 2 mph slower than the second. Just 200' in elevation will not creat such a great difference in ET & mph. Really makes you scratch your head to the exact cause to the ET & mph difference.
You are correct on both issues. There are always little things about every track, and people were bitching about burning up their cars the last 66' just for a better MPH, the race was already over.
The little crappy track near me has always had short 60' lights. If you get a good launch, the 60' will be a tiny bit better than other places, but the ET is the exact same per weather. We know for a fact the track is not hooking better than other tracks, because we have to soften the launch 75% of the time. So obviously it's in the equipment, if dozens of people get the same results.
I also read an article, where a guy secretly measured a bunch of tracks, and found a bunch of old tracks were short, 10, 30, 50 feet. He said most new track were good. He also claimed on one track, the elect system was so old, that when the food trailer was cooking something, the ET would be slower from the power drain. Slowing the clocks down????
Be safe everyone.
When we first started using data management, logging engine RPM vs drive line RPM and plotting events at various track locations, that sort of stuff drove us nuts!...especially when some of the tracks started looking to be 20 to 100 foot short!!
Thanks for all the replies guys, good info in here.
For some reason the 66' thing sticks in my head but different timing systems may use a slightly different length traps for mph.
