Drag Racing Tech
QA1 doubles or AFCO's???
Old Nov 6, 2006 | 06:02 PM
BLk01SS's Avatar
Question QA1 doubles or AFCO's???
What do you think is better?? Are the AFCO rears a coilover conversion???
Thanks,
Tre
Old Nov 6, 2006 | 06:22 PM
stevemilz's Avatar
Afco's are big$$$$$
Old Nov 6, 2006 | 06:32 PM
stevemilz's Avatar
I have a Strange Coil over kit on my car. The Afco's are most likely the best, does everbody need them? I dont think so, I have a buddy that run 9.3x's with 50/50 Lakewoods.
Old Nov 6, 2006 | 06:47 PM
Schurters LT1's Avatar
how do the strange compare to the QA1s ??
Old Nov 6, 2006 | 06:49 PM
stevemilz's Avatar
The car isnt done yet
They were cheap
Old Nov 6, 2006 | 07:01 PM
1QuickT-A's Avatar
They are both good shocks.. The price difference isn't huge, but I believe the Strange pieces are a little cheaper. AFCO's are the best, but you don't really need them on a 9-12 sec car either.
Old Nov 6, 2006 | 07:25 PM
Fireball's Avatar
FWIW, I've discussed this with MADMAN. He doesn't care for the QA1s, he said they were unpredictable to different inputs.
He rated AFCO #1 and Strange as his 2nd choice
Old Nov 6, 2006 | 07:42 PM
Can you do the coil over with all of them ????
Old Nov 6, 2006 | 07:45 PM
1QuickT-A's Avatar
I'm pretty positive that you can... I know you can with the AFCO and QA1's so I'm sure the Strange is the same in that aspect.
Old Nov 6, 2006 | 07:50 PM
i really would like to have to coil over just so i can adjust ride height.....with all the extra wight in the front from the blower and intercooler....
Madman said that the AFCos are the best hand down.....but the $$$$$
Is there anything wrong with the QAIs....or should i look at the strange ?
thanks
Old Nov 6, 2006 | 08:27 PM
Fireball's Avatar
thanks
Madman just said that he'd change the setting with no apparent change in how the car reacted...very unpredictable
Old Nov 6, 2006 | 08:34 PM
NA$TY-TA's Avatar
I love my Strange DA Shocks...... they work for me....
Old Nov 6, 2006 | 08:50 PM
JMBLOWNWS6's Avatar
My QA1's work like a champ. I adjust them and they do what there suppost to do. I respect Madman and all the work he does. But I disagree with his commment. Maybe he had a bad set or something was wrong with the valve in the shock.
Old Nov 6, 2006 | 09:00 PM
1QuickT-A's Avatar
The QA1's have worked well for me.. I adjusted mine down from 4 clicks to 2 clicks saturday night and I could tell a huge difference. It wouldnt hook on the motor (1.68 60ft N/A spinning) with them on 4 clicks so I put them on 2 clicks and sprayed it and it went 1.45 60ft. So, they work... You will find QA1's on the majority of the fast cars on this board. The AFCO's are better shocks, but I don't think they are needed unless you are making some serious power and running really fast.
Old Nov 7, 2006 | 06:45 AM
MADMAN's Avatar
LS1Tech Sponsor
If you are going to the double adjustables shocks then either the AFCO or the Strange is the way to go. The QA1 vavling isnt right and the piston is too small to work properly on extension. I have had quite a few customers try them and we have taken them off and replaced them with a quality shock and the car has reponded.
__________________
www.madmanandcoracing.com
225-343-9029
Old Nov 7, 2006 | 11:04 AM
kp's Avatar
kp
I have had both the AFCOs and stranges on the back of my car. The AFCOs are nicely made but they really need to step into the 1960's and at least put some clicks on the adjuster on top so you know where you are for that kind of money, 1/16 of a turn makes a huge difference on them.
I would buy the Strange DA rears to be honest, but to be really honest none of them worked any better then the 50.00 50/50 CEs I'm using now lol - granted 1.28 60's for a 3450lb car isnt all that great..
Old Nov 7, 2006 | 12:15 PM
MADMAN's Avatar
LS1Tech Sponsor
KP your wish is coming. The new AFCOs will be out by PRI.
__________________
225-343-9029
Old Nov 7, 2006 | 01:17 PM
kp's Avatar
kp
Thats only half my wish, the other half is they cost 50% less
But they are very nicely made shocks.
Old Nov 7, 2006 | 02:06 PM
jshiver's Avatar
So how do you know where your adjustment is on Afco's if they don't click?
Old Nov 7, 2006 | 02:36 PM
MADMAN's Avatar
LS1Tech Sponsor
You have to look. They are numbered with an arrow.
__________________
225-343-9029
