Electric vacuum pump help-recommendations
#41
Originally Posted by xssive
Hmmm, looks strikingly familiar
![](http://images.auctionworks.com/hi/62/61874/215-425--.jpg)
But in the pic you posted, it sure does look identical..
In that case, and since madman and brady arent responding much, I would guess you guys are right about the air pump deal. And it would be for a drag only car as I know the factory pieces arent designed to handle oil or run for extended periods of time.
#42
LS1Tech Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I had one on my last car, it was definitely a "drag only" type application, in fact I burnt one up street driving with it. The electric pump seemed to work very well but I don't have any data to back it up. I'm going to run one on the new car and I'll be able to provide some crank case pressure readings as recorded by the Big Stuff 3.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
#43
#44
That is basically the same thing as the pumps on the LS1 cars. I know of a local racer that has one on his 408 small block dodge and it pulls around 3 inches of vacuum. I figure the belt driven pumps are better than this particular setup however the electric pump the pro stock guys are using pulls somewhere in the mid 20's.
#47
Thats not an f-body pump that I showed, but it is infact a gm pump for a hell of alot thess than 350$
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#48
6 & 8 Second Club
Hey wicked, do u know what make and model they are using to get 20 + with an electric. Hell, I would be in heaven to get 15 ish. If all these pumps are making is 3-6, I'm buying another Moroso.
#49
LS1Tech Sponsor
Originally Posted by Fire67
When you get that data, please post up so we can see the results. How much street driving did you get out of it before it burnt up?
I basically got no street driving out of it, one race we went to (World Street Race), we had a 30+ mile drive, and when I got back the pump was locked up...
__________________
2016 Z07 Carbon
2016 Z07 Carbon
#50
I'll post results.
Nice, no little cruises with that pump! lol...
I wonder what pump the pro stock guys are using to pull that much vacuum and if they'd be reliable enough to include short cruises in a strip/street car?
#53
Originally Posted by calongo_SS
Yes, It could be wire to a WOT switch.
The crankcase has to vent somewhere all the time
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Plus with these things only capable of pulling 5-6" of vacuum, only running at WOT throttle you may never see that much vac. do to the higher rate of crankcase gasses being produced.
#54
#55
I bet the PS guys are running something like this:
http://www.starvacuumpumps.com/viewP...=STR.04.06.000
#56
That one's 24V, so it would need its own battery... The one with the kit is probably one of the drill batteries Ive heard of these guys using.
Amazing the money people spend on this stuff... It seems like it would almost be cheaper to get a pulley drive vac pump, mount it remotely and drive it with a 12V electric motor of sorts.
#57
I bet that is the pump they're running, seems like I remember someone mentioning them being 24v pumps.
BTW, pro stock is not a budget racers game, money should be no object and even then don't expect to be competitive.
#58
6 & 8 Second Club
I know I'm not switching to 24V. So that takes care of that. I had about 15ish with my belt drive, and I actually took off the valve for a vent system a few years ago and never had a problem. Some Comp Elim guys spend as much as Pro-Stock, so I would bet they have some pretty trick stuff. Thanks for trying everyone.
#59
Too bad this stuff is so expensive, as with the procharger, I really have no way of running a belt drive, unless I got someone to cut a cog pulley into my Procharger pulley spacer.
#60
That's MISTER MODERATOR
I've been told by many guys over the years that running a crank case vacuum pump will add horsepower to any engine. Something about helping to keep the piston rings seated.
Now, I'm no expert here so I'm trying to learn.
How would one go about installing an electric pump on a daily driver?
I doubt any of the electric pumps discussed here would last very long for continuous duty.
Although I'm sure this won't work, what do you guys think about the SSBC 28146?
![](http://www.ssbrakes.com/commerce/images_products/28146.jpg)
