weight reduction-worth it?
Paul
That depends on your power level. 100 lbs on my car has shown to be .06 to .07 sec. I have a friend that has run several fast NHRA Comp eliminator cars, and changes classes by adding or removing weight, and he says he can figure on .05 sec per 100 lbs. Of course, he makes a couple hundred more hp that I.
I tell guys pounds are the same as hp.
On a heavier car 100 pounds is not that high of a percentage of weight. Say 100 pounds out of a 4200 pound impy is not that much.
Now 100 pounds out of a 2800 pound car would be a lot more and cut more time because its a higer percentage of weight being pulled?
For example (just throwing out numbers)
10 pounds in a 100 pound go cat is a 10% weight reduction
10 pounds in a 1000 pound car is a 1% weight reduction.
Dan
Bumper Supports!
AC!
Heat!
Radio! and Speaker!
lightweight carpet
light seats
skinnies
15X10s out back
inner fenders!
abs!
PS!
QA1's and Springs
No power Brakes/Brake booster
all susp. is chromoly and tubular
Basically all the free stuff on the weight reduction list
Dan
1000lb car 100hp your power to weight ratio is 10lbs/1hp
a 2000lb car 100hp = 20lbs/1hp
now say its a 4000lb car and you have 1000hp power to weight would be 4lbs/hp
now say 3900lbs with 1000hp= 3.9lbs/hp
now it should be easy to see how depending on the application what losing weight really does for you.
just for the hell of it something a little closer to our cars.
3500lbs with 300hp = 11.66lbs/hp
3400lbs with 300hp = 11.33lbs/hp
3500lbs with 400hp = 8.75lbs/hp
3400lbs with 400hp = 8.5lbs/hp
Pays to be skinny.
Pays to be skinny.
Another run for me the night before was a 6.050 with a 2600 DA with a track temp around 85. My dad was running with 2900 DA on a 130 degree track and still running 6.071's.
Regardless this isn't the greatest comparison given it's different tracks/weather and you are right about me picking up even more in the 1/4 mile because of the lack of weight I was just trying to provide an example.
We might put my dads 548 which has run a 6.06 in a 3150 pound car into my car that will be 2825 with me in it so I am hoping to gain around 2 tenths via less weight then put it on alcohol to gain another one so hopefully some 5.60's.
