exhaust?
You need more pipe than open headers otherwise you will burn up your 02 sensors.
Maybe a bit more power down low with true duals.....but I don't know about you, but when I drag race I'm NEVER below 4k rpms. I also happen to be friends with the creator of this thread and he bought this car with intentions of making it a stripper and cutting off every unnecessary pound.
I asslume if it's a bolton car you are gonna make a run at the stock internal record? If that's the case, you'll benefit more from the weight loss then any bottom end tq that an exhaust would make
I've heard different. Never actually tested it myself though.
I bet if magnus sees this, (one of the fastest SI cars ever) I'm sure he will chime in and answer the question.
Here you go if you don't believe me:
https://ls1tech.com/forums/drag-racing-results/598343-new-stock-internal-record-10-92-121-mph.html (Project_SS)
I ever start another ls1 project car I will make a point to do the entire car first and leave a stock motor in it for at least a good part of a season to disprove this "theory"
with roughly 350 rwhp (stock internal motor with all the boltons), I'm sure that even with a low end power loss, losing 40 lbs of exhaust pipe would be more beneficial then more power on a race car that is never below 5000 rpm the whole way down the track.
