Wolfe bolt-in roll cage - help!!
i have the wolfe 5-point bolt-in cage and getting ready to install it.
The roll cage looks like this:
My question is about the rear 2 bars bolt down just above the gas tank (as shown in the above picture). I crawled underneath the car to see where the bolt holes will come out when I drill them. There appears to be a gas tank there. Bad, very bad..
Do I need to remove the gas tank to drill these holes in the back? Or is there enough clearance to drill the holes without accidently drilling through the gas tank?
I am pretty sure you have to remove the tank. it says so on there site.
"Installation: Requires removal of seats, some interior plastic and carpet. Bolts to floor with plates above and below the floor with 4 bolts each point (per NHRA requirements). Can be installed with hand tools and a drill in a few hours. Fuel tank must be dropped if installing with Over Seat Rear Bars."
