Drag Racing Tech
Is it harmful to run open headers?
Old Mar 12, 2007 | 05:08 PM
00 Freak's Avatar
Default Is it harmful to run open headers?
Is it better to have a exhaust sys. or can you actually run better with open headers. I wasn't sure because of a back pressure issue. What do you guys think?
Old Mar 12, 2007 | 05:14 PM
edwardswb's Avatar
back pressure is a non issue. Scavenging!!! You will lose a little low end torque and gain high rpm horsepower. If you want some of that torque back, get some 12-18 inch extensions with turndowns. You could have problems with your o2 sensors screwing up your A/F ratio due to them not heating up properly if you just run open headers. (too close to open air)
Old Mar 12, 2007 | 05:23 PM
00 Freak's Avatar
Well the car did pretty good. It ran a 7.2s@93.7mph open headers. My TD's came off when loading the car on the trailer. Needed to get to the track and didn't bother putting them on.
Old Mar 12, 2007 | 06:29 PM
brandonppr's Avatar
here is an interesting post about backpressure:
http://forum.camarov6.com/showthread.php?t=77275
Old Mar 12, 2007 | 10:39 PM
mrdragster1970's Avatar
6 & 8 Second Club
We all use open headers, some of the milder guys run an extension collector.
Old Mar 13, 2007 | 12:23 AM
boondiggys's Avatar
a bit off topic but mr 1970 what is that guy doing touching the quarter panel in the NA test test, just before you launch?
Old Mar 13, 2007 | 07:39 AM
camaronut502's Avatar
hes probably turning something that will record the run.
Old Mar 13, 2007 | 11:31 PM
6 & 8 Second Club
Data recorder switch, even when we're not racing, we always use it, we actually caught an exhaust spring going weak one time, just out scuffing up new tires.
Thanks for watching, hope you didn't fall asleep.
Old Mar 24, 2007 | 11:53 PM
boondiggys's Avatar
no not at all, but id like to give you a fan to get that smoke out of the cockpit after you burn out, but im not sure you want the extra weight.
ttt for the starter.
Old Mar 25, 2007 | 09:50 AM
James Montigny's Avatar
Just duct the hot exhaust gases away from your floorboards. (turndowns, or side exit)
Catching fire is not fun. Trust me ... been there, done that, lost the tshirt.
Old Apr 4, 2007 | 07:04 AM
White2000TA's Avatar
Im thinking of running open headers as well. My concern is the O2s and I also have a wideband that I would like to use. I guess you could use small extensions or sides and put a spot for the wideband there. How far from open air is good for the sensors in general?
Old Apr 4, 2007 | 07:28 AM
anyone got pics where they exit it on the side?
Old Apr 4, 2007 | 07:42 AM
RUQWIKR's Avatar
Also it depends on if you get reversion and gives false 02 readings. On my MAC's, when I tried open headers, I put a bolt-on 6" extension on them to keep from false readings. However, I personally prefer the tone of my custom-length mufflers on vs. open headers...we saw no horsepower loss with them and they are only 2.5" versions.
This weekend, weather permitting, I'll be trying a different header combo and running open only until my new mufflers come in. Good luck. Dave
Old Apr 4, 2007 | 10:26 AM
tim99ws6's Avatar
Just run a bullet-style muffler off the collector. It'll flow just as well, give you the length you need, and quiet the thing down a little!
I run Edelbrock stepped LT's/3.5" Moroso spirals/flowmaster turndowns turned out to the side.
It's a very basic/clean setup IMO
