Drag Racing Tech
Anyone have this problem when installing linelock?
Old Mar 16, 2007 | 10:47 PM
2_wacko's Avatar
Default Anyone have this problem when installing linelock?
The line that go's into the resivor is so freaking tight. I'm affraid to keep trying to break it loose can anyone help me out?
Old Mar 16, 2007 | 11:16 PM
1320FEVER's Avatar
Go to autozone and get some penetrant and spray on it. It'll come right off.
Old Mar 17, 2007 | 12:22 AM
SJM Manufacturing Inc's Avatar
Use a line wrench, that will help it out a bit. If you're not using the line over, just cut it off and use a socket, this way you'll be applying an even pressure over the nut.
If you need anything or a new fitting, please let me know.
Old Mar 17, 2007 | 12:36 AM
JPMuscle's Avatar
IF you can get a set of vice grips on it that will work as well
Old Mar 17, 2007 | 01:08 PM
2_wacko's Avatar
With the line wrench it was still slipping, vice worked great. Now I just cant get the solenoid to click .
Old Mar 17, 2007 | 01:30 PM
LC's Avatar
LC
have you tried connecting it to a 12v terminal and a proven ground?
Old Mar 17, 2007 | 01:34 PM
2_wacko's Avatar
I have it to a good ground and the 12v is coming from the cigarette lighter?
Old Mar 17, 2007 | 01:35 PM
2_wacko's Avatar
BTW I have not bleed the brakes yet?
Old Mar 17, 2007 | 01:42 PM
LC's Avatar
LC
Have you checked the wiring?
Check the fuse on the cig lighter...
are you using a specific kit?
Old Mar 17, 2007 | 02:31 PM
2_wacko's Avatar
Found the problem the 2 way connector had not cut threw the 12v source clicks loud and clear now.
