What e.t. difference with Drag wheels compared to stock?
I am trying to find concrete numbers as to what kinda e.t. gains there are by switching, since I know its about a 70-80 pound weight drop, but what does that translate into at the track?
I would like to negate the traction difference, but realize that would be hard, since the 15" DR's are gonna give better traction because of the larger sidewall. I am really wanting to know what kinda gains will be realized from the lighter wheel/tire combo.
Please, someone that has raced there car with each type, give me some numbers between the two.
Thank you, James.
Matt speaks the truth and its the same with all mods.
One day a cam might run .8 faster, the next .7.
All depends on the track and weather conditions.
I am basically looking for a statement like this;
"I had 17" wheels with drag radials and ran a XXX e.t. at the track, then I switched to 15" drag wheels with drag radials and ran XXX e.t."
If some can make such a comment, then this is what I am looking for, not really the reasons for it being hard to get the numbers
WS6HUMMER, do you have an comparison between your stock wheels and the drag wheels? This is what I'm really after.
Thank you, James.
Ive always been told that every 100 lbs is worth a tenth(.10)
The weight gone and the same 60" as before you should be faster....
usually you don't take off much weight on the rears - it's all in the skinnies. i'd say most people have experienced, around 1.5-.2 going from stock front wheels and tires to skinnies.
i gained a solid .2 in my orange car - went from 11.42 to 11.22. but those runs were made two weeks apart so weather could have been different.
The main thing I noticed 2nd Gear was just a little spin instead of a smoke show I reccomend a line lock for an M6 (me) because you gotta really heat them Dr's up in the water box
Starting off like I said i got 3 tenths in the 60'' almost a dead hook off the line I should have took the frount sway bar off stupid me !!! it just spun the very begining of 2nd and 3rd no spin at all on a good run on my street tires 3rd would chirp a little now its the same but in 2nd gear difference is night and day i got 4 tenths (.4 off my et in an 1\8 mile) pretty good mod Id say
http://www.mickeythompsontires.com/tech.php?bulletin=s1
Pointed out by a buddy of mine
Car ran 13.10's all day. 100% STOCK, not even a lid. Added nothing, took nothing away, other than the wheel and tire swap and it ran 12.5x's all day. Car was an 01' 6spd btw.
