Drag Racing Tech
Wiring For Harlan 2 Step!!
Old Apr 9, 2007 | 10:02 AM
NickcZ28's Avatar
Default Wiring For Harlan 2 Step!!
ANYONE have a wiring diagram for how to wire a harlan 2 step??
thanks
Old Apr 9, 2007 | 10:20 AM
nutz'00 Z28's Avatar
https://ls1tech.com/forums/attachmen...chmentid=39259
Old Apr 9, 2007 | 01:35 PM
Steve Burger's Avatar
LS1TECH Sponsor
I would like to know how to wire this into a trans brake button.
Old Apr 9, 2007 | 01:39 PM
LS1SpeedAddict's Avatar
I would also like to know
Old Apr 9, 2007 | 02:50 PM
NickcZ28's Avatar
Yes That would have been nice when I had the th400, now its a M6..Thanks!
Old Apr 9, 2007 | 05:48 PM
Use a relay. Split the 12v out from your transbrake switch, one goes to your t-brake the other to a relay that will connect gray and white wire together when supplied with the 12v. Here is a quick drawing, double check the numbers on the relay I am not 100% sure on them.
Old Apr 10, 2007 | 07:03 PM
NA$TY-TA's Avatar
Id have to pull my console to be 100% sure on mine....... it works though LOL
Old Apr 30, 2007 | 07:28 PM
SSPerformance's Avatar
thoes #s dont work any got the rite #s?
Old Apr 30, 2007 | 08:02 PM
alright here it is this should be correct.
File Type: doc
Old Apr 30, 2007 | 08:54 PM
only thing u did was change 85 and 86
Old Apr 30, 2007 | 08:59 PM
well I just looked at the box my relay came in:
86=Ground
85=12v Switched source
30=Input
87=Output
When 12v is applied to 85 it should complete the circuit between 30 and 87.
Old Apr 30, 2007 | 09:11 PM
so the wiring diagram is wrong....? i get no power to #87 and ive tried a few relays to make shure i dont have a bad one
Old Apr 30, 2007 | 09:24 PM
you shouldn't get 12v to 87. Is the relay clicking when you have it grounded and supply 12v to to 85? Use a continuity(sp.) tester when 12v is supplied to 85, 87 and 30 should show continuity, then when 12v is removed it should break the circuit.
Old Apr 30, 2007 | 09:27 PM
yes when 85 and 86 are wired you can hear the relay click.... shoudlent u get power @ 87 when u press the t-brake button to ativate the 2 step..... my 2 step dosent work and i go tno power @ 87
Old Apr 30, 2007 | 09:30 PM
The 2 step draws power from the coil pack wiring I believe all you are doing is completing the circuit by grounding the 2 step, I changed the diagram above and added the instructions for the 2 step.
File Type: doc
Old Apr 30, 2007 | 09:34 PM
the new diagram is total diff i will give it a try tomorrow.... is that how u have urs setup?
Old Apr 30, 2007 | 09:44 PM
Thats how mine is wired up, the grey wire can either be connected to a ground, white wire, or 30 on the relay its not important, just as long as it gets grounded when the relay is active. The activation wire is the white wire. when it gets grounded the step is armed.
Old May 2, 2007 | 05:23 PM
works now thanks for the help
