Drag Racing Tech
stud size
Old Apr 10, 2007 | 06:31 PM
headsupkid01's Avatar
Default stud size
Will a 3.25 stud work with a set of weld prostars and if so will they be to long for my stock 17x9 lug nuts when i go to put my street wheels back on?
Old Apr 10, 2007 | 08:22 PM
wild thing's Avatar
Are you going to use spacers on the rear or do you have a set of race calipers that will clear the rims.If you are runnings 15's you will need spacers with stock brakes.
Old Apr 10, 2007 | 09:02 PM
I was not to going to run a spacer on the rear. As far as the caliper i was going to grind the stock ones.
Old Apr 10, 2007 | 09:03 PM
SiL3NtXWS6's Avatar
i run the 3.25 on my car and it works fine with prostars.. i need the 3.25 to be legal.
It sticks out past the wheel a good inch with street wheels, does not matter to me though, nobody stares at those when driving.
Old Apr 10, 2007 | 09:19 PM
So i guess you can't get your lug nut caps back on then. And the stock stud is a 12mm 1.5?
Old Apr 10, 2007 | 09:22 PM
SiL3NtXWS6's Avatar
no i can't get my lug nut caps on hah
Old May 2, 2007 | 03:23 PM
JL ws-6's Avatar
Race your car!
silent, when you swapped teh studs how did you get the old ones out... whackamole style, or is there an easier way?
Old May 2, 2007 | 03:50 PM
SiL3NtXWS6's Avatar
couple hits with a hammer and they will pop right out. I think that is the easiest way, shouldn't take more than 10 seconds per stud
Old May 2, 2007 | 07:51 PM
JL ws-6's Avatar
Race your car!
swapped the front tonite, took abotu 45 mon to do both sides.. teh rear I'm gonna have to take apart to get to the studs... that's tomorrow's project.
Old May 2, 2007 | 11:03 PM
I put the 3.25s on my car a week ago and they were way to long for my prostars. I had to cut them down to damn near stock size.
Old May 2, 2007 | 11:25 PM
Matt D's Avatar
Retired Street Racer
I have the 3.25" on mine, ARP Part # 100-7713. The easiest way to do it is to just pull the axles.
Old May 3, 2007 | 06:17 AM
SiL3NtXWS6's Avatar
I have the 3.25s on my car with prostars and they are barely long enough to pass tech.
Old May 4, 2007 | 06:19 AM
Matt D's Avatar
Are you running a spacer? They should be long enough.
I have Convo Pros and they are definitely long enough to pass.
Old May 4, 2007 | 07:07 AM
SiL3NtXWS6's Avatar
with a small spacer, it's a no go by about a milimeter, with no spacer, it will barely pass. I'm talking bare minimum. Maybe i need to trim my lugs?
Old May 4, 2007 | 08:55 AM
Matt D's Avatar
I wouldn't trim your lugs, I would buy a different brand that is not so long. Like these:
http://store.summitracing.com/partde...0&autoview=sku
That is why I didn't go with Prostars again on this car. The fact that you have to use such a long lug nut and you have to grind your calipers
