how fast is 475hp in the 1/8
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
475 rwhp in a good set-up suspension, trans and gearing should net 6.60s at 103-105 mph in a 3400-3500 lb car. 475 hp at the flywheel would be more along the lines of 7.20s-7.40s at 92-94 mph.
Derek
Derek
the car is 02 ta 6speed p1 procharger dynoed 475hp 450tq at 6psi stock gear longtubes i thought the speed was a little slow for hp maybe dyno was alittle off would the speed go up with a better 60ft how did you launch with stock rear
Administrator
Your 1/8th ET & trap speed will be completely dependent upon the tranny you're
running in combination with your suspension setup (wheels/tires too).
You can make all the power in the world and lay down a horrible run. I see
guys run 8.0's @ 90mph with 500rwhp...and I also see guys running 6.50's @
110mph with 500rwhp.
Originally Posted by justin wollard
thanks for replying would my pick up any mph with a 4.10gear
Heck, 4.10 may make a world of difference, but without know anything about the car, it is impossible to know how to help you.
Build a signature block to tell us about your car before you ask questions please.
David
