5pt harness mounting question
Thanks, Brad
"Basic NHRA Safety Rules
Seat Belts
All cars must be equipped with an accepted quick release type driver seat belt. All cars in competition
requiring a roll bar or roll cage, or as outlined by Class Requirements, require a Driver Restraint System as
outlined below.
Driver Restraint Systems
A quick-release, 3-inch shoulder harness meeting SFI Spec 16.1, including crotch strap, is mandatory in all
cars in competition required by the rules to have a roll bar or a roll cage. Driver restraint system must be
clearly labeled as meeting SFI Spec 16.1 and be dated by manufacturer. System must be updated at two-year
intervals from date of manufacture. All seat belt and shoulder harness installations must be mutually
compatible, originally designed to be used with each other, and produced by the same manufacturer. Cars
using OEM or OEM type seat may route crotch strap in front of seat instead of through seat. Only those units
that release all five attachment points in one motion are permitted. When arm restraints are worn with a
restraint system that utilizes a "latch lever", a protective cover must be installed to prevent arm restraint
from accidentally releasing the latch lever. Protective cover not needed if system uses "duckbill" latch
hardware. All harness sections must be mounted to the frame, crossmember, or reinforced mounting, and
installed to limit driver's body travel both upward and forward. Seat belts may not be wrapped around lower
frame rails. Under no circumstances are bolts inserted through belt webbing permitted for mounting. Check
manufacturers instructions."
I know it didn't say crossbar but maybe the rulebook states it for both.
-Mark
The 'Y' type wraparound shoulder belts are no longer legal though, the tech guy was wrong if you had individial wraparound belts.
