Drag Racing Tech
26 vs 28 inch tire?
Old Apr 17, 2007 | 07:03 PM
Out1aw's Avatar
Default 26 vs 28 inch tire?
What are the advantages/disadvantages of running a 26" compared to a 28" drag radial on a 3.73 geared 12-bolt rear in a 400-450rwhp car?
Old Apr 17, 2007 | 07:27 PM
5_02ls1's Avatar
i personaly dont see how a 28 fits under the car because my 26s barely clear.the bigger tire will normally hook a lil better and net you more top speed
Old Apr 17, 2007 | 07:31 PM
gator's 99TA's Avatar
pros: better traction or easier more consistent launches
cons: need gearing to compensate and possibly some work to get the tire to fit.
Old Apr 17, 2007 | 09:15 PM
TwoFast4Lv's Avatar
At that level not much of an advantage IMHO.
I am bumping up to 28s for 27s to get a little better hook and some more top end RPM>
LT1s are PCM Hard limited to 7,200. I have a 7,200 MSD chip in it to keep from hitting it but I have been clipping it just before the traps at 136ish
Old Apr 18, 2007 | 08:31 AM
AL SS590 M6's Avatar
I guess that would depend upon how your car is set up and how high it sits. Mine has 27"s on it now and clears everything by a least an 1" so I got some Hoosier 275-60x15 Drag radials which are 28" for this season to keep my rpm down and to help with consistancy.
Old Apr 18, 2007 | 08:32 AM
slow95z's Avatar
28s fit just fine on my car
Old Apr 18, 2007 | 10:19 AM
bowtierodder's Avatar
i have 275/60/15 m/t drag radials which are 28" tall on 15x8 prostars with 5.5 b/s and they fit fine
Old Apr 18, 2007 | 11:31 AM
sbusby's Avatar
You will be loosing your gear ratio, which was mentioned above.
Old Apr 18, 2007 | 12:33 PM
purdueranger's Avatar
Will a 27" tall tire fit with rolled fenders and the car on LG G2 lowering springs?
Old Apr 18, 2007 | 04:32 PM
easily. i ran 28x9 et drags for years. they measure 27.3"
Old Apr 18, 2007 | 06:22 PM
Thanks.
Old Apr 18, 2007 | 07:01 PM
02SOMWS6's Avatar
28" tires will fit . they fit fine on my car
Old Apr 18, 2007 | 09:03 PM
5_02ls1's Avatar
im using a 10.5" tire maybe thats why they dont fit well.
