Drag Racing Tech
need help with proportion valve
Old May 3, 2007 | 10:30 AM
jldak318's Avatar
Default need help with proportion valve
i figured i would ask here cause most of yall guys have prob already done this. im deleting the abs control box and want to put a proportion valve in its place. if anyone has done this can you give me a link to which one you used and/or pics of it in the car so i can see how to route my brake lines. thanks.
Old May 3, 2007 | 10:53 AM
MADMAN's Avatar
LS1Tech Sponsor
What master cylinder do you have?
__________________
www.madmanandcoracing.com
225-343-9029
Old May 3, 2007 | 10:58 AM
jldak318's Avatar
stock
Old May 3, 2007 | 11:01 AM
MADMAN's Avatar
LS1Tech Sponsor
__________________
225-343-9029
Old May 3, 2007 | 12:57 PM
CatchinZs's Avatar
Check out SJM in the sponsor list. They have a kit for the ABS delete.
Madman,
Is it not recommended to use the stock master cylinder with a proportioning valve? This is the first I heard this.
Old May 3, 2007 | 12:58 PM
jldak318's Avatar
damn it madman, help me out. lol.
seriously i thought i would need a proportioning valve for brakes like tim h has on his car.
Old May 3, 2007 | 01:00 PM
jldak318's Avatar
http://www.jegs.com/webapp/wcs/store...62853_-1_10165
this is what i was thinking of using but wasnt sure if i could.
Old May 3, 2007 | 02:17 PM
fitz98ta's Avatar
http://www.jegs.com/webapp/wcs/store...0002_127906_-1
this is the one i am using, works great for me.
i am sure that any adjustable will work just as well
Old May 3, 2007 | 02:28 PM
Matt D's Avatar
Retired Street Racer
I ran the Wilwood valve with a Hurst Line Lock from SJM & the stock master cylinder and never had a problem.
Old May 3, 2007 | 03:13 PM
DrkPhx's Avatar
Originally Posted by MADMAN
Damn, you are brutal.
Old May 4, 2007 | 07:55 AM
jldak318's Avatar
he is really a nice guy for the most part.
Old May 4, 2007 | 12:57 PM
bowtierodder's Avatar
is there a write up for the abs delete?
Old May 4, 2007 | 01:14 PM
Fire67's Avatar
lots of them. Do a search when its working again.
Old May 4, 2007 | 01:26 PM
MrDude_1's Avatar
ive always used the wilwood one... it actually weighs less then the length of steel line it replaces.. lol.
the rear master cyl port controls the front brakes.. so it goes from the master cyl, to the line lock, then to a T with one line to each brake.
the front master cyl port controls the rear brakes.... so it goes from the master cyl, to the prop valve, then back to the rear brakes...
just make sure that under a panic stop, the fronts lock before the rears.. lol...
