Am I due for a change of gears?
I have your basic bolt-on car with a mild heads/cam package. Mods in Sig.. What ET difference would I notice with a 4:10 gear vs my stock 3:42?
Cam peaks about 6300 if that helps, and the cam was designed to move peak torque a bit higher in the rpm range as well. If it's just a tenth I won't worry much about it. I was thinking along the lines of .2-.3 and 2 mph or so (hoping).
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
What is the car going through the finish line at for rpm? The gear will enable you to go through the gears quicker, but also may over-rev the motor before the finish line depending on tire and such.
Derek
Derek
